주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dyson DC39 Origin Cyclone Filter Replacement
필요한 것
    1. Dyson DC39 Origin Cyclone Filter Replacement, Bin: 1 단계, 이미지 3개 중 1개 Dyson DC39 Origin Cyclone Filter Replacement, Bin: 1 단계, 이미지 3개 중 2개 Dyson DC39 Origin Cyclone Filter Replacement, Bin: 1 단계, 이미지 3개 중 3개
      • Push down on the gray button located next to the power button to release the bin from the ball housing.
      • Pull the bin away, then up from the ball housing to remove it.
      • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
      댓글 쓰기
    1. Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: 2 단계, 이미지 3개 중 1개 Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: 2 단계, 이미지 3개 중 2개 Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: 2 단계, 이미지 3개 중 3개
      • Remove the purple pre-filter by pulling it up and out of the bin.
      댓글 쓰기
    1. Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: 3 단계, 이미지 2개 중 1개 Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: 3 단계, 이미지 2개 중 2개
      • Push down on the red button, located on top of the bin, to release the bottom section of the bin.
      댓글 쓰기
    2. Dyson DC39 Origin Cyclone Filter Replacement: 4 단계, 이미지 1개 중 1개
      • Push the grey button located in between the parts of the red lever to release the clear, bottom section of the bin.
      • The grey button can only be pressed after the bottom section is open.
      댓글 쓰기
    3. Dyson DC39 Origin Cyclone Filter Replacement: 5 단계, 이미지 3개 중 1개 Dyson DC39 Origin Cyclone Filter Replacement: 5 단계, 이미지 3개 중 2개 Dyson DC39 Origin Cyclone Filter Replacement: 5 단계, 이미지 3개 중 3개
      • You should notice several notches around the rim of the filter. Slide the plastic opening tool around the rim to release the notches.
      • After releasing all of the notches, pull the filter away from the orange cyclone assembly to remove it from the bin.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sam Nelson
회원 가입일: 04/26/17
167 평판
안내서 1개를 작성함
Cal Poly, Team S23-G6, Livingston Spring 2017 Cal Poly, Team S23-G6, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S23G6
3 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 57
전체 시간: 4,086
