주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dyson DC58 Main Body Replacement
필요한 것
동영상 개요
    1. Dyson DC58 Main Body Replacement, Bin: 1 단계, 이미지 1개 중 1개
      • Make sure your vacuum is unplugged.
      • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
      댓글 쓰기
    2. Dyson DC58 Main Body Replacement: 2 단계, 이미지 1개 중 1개
      • Locate the red lever parallel to the red trigger and on the side of the clear bin.
      댓글 쓰기
    3. Dyson DC58 Main Body Replacement: 3 단계, 이미지 1개 중 1개
      • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
      댓글 쓰기
    4. Dyson DC58 Main Body Replacement: 4 단계, 이미지 2개 중 1개 Dyson DC58 Main Body Replacement: 4 단계, 이미지 2개 중 2개
      • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
      댓글 쓰기
    1. Dyson DC58 Main Body Replacement, Main Body: 5 단계, 이미지 1개 중 1개
      • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
      댓글 쓰기
    2. Dyson DC58 Main Body Replacement: 6 단계, 이미지 2개 중 1개 Dyson DC58 Main Body Replacement: 6 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
      • Use tweezers to pinch the two visible white clips together.
      • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
      댓글 쓰기
    3. Dyson DC58 Main Body Replacement: 7 단계, 이미지 1개 중 1개
      • Tilt and pull the main body away from the purple cyclone of the vacuum.
      • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Krista St Onge
회원 가입일: 09/17/15
2,260 평판
안내서 2개를 작성함
CSU Fullerton, Team 2-4, Bruce Fall 2015 CSU Fullerton, Team 2-4, Bruce Fall 2015 회원
CSUF-BRUCE-F15S2G4
4 회원들
안내서 24개를 작성함
4가이드 댓글
Mine ended up dismantled after it had been dropped. Couldn't get it back together until I read the bit about the tweezers /(pliers) and the white clips. It does not push in with out squeezing them first
Jason - 답글 공유
Has anyone replaced the red release catch?
chrisashton1 - 답글 공유
The white C-ring with clips must be pushed down in order to reassemble device. Takes some time to practice.
Anton Simonov - 답글 공유
I'm trying to figure out how to put spring and plastic pieces back in on the inside of red lever on motor body?? Any help I'd really appreciate ?
t_picano - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 74
전체 시간: 14,678
