주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Eee Pad Transformer Prime TF201 LED Chip Replacement
필요한 것
    1. Eee Pad Transformer Prime TF201 LED Chip Replacement, Opening Your Device: 1 단계, 이미지 1개 중 1개
      • Power down your device.
      • Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
      댓글 쓰기
    2. Eee Pad Transformer Prime TF201 LED Chip Replacement: 2 단계, 이미지 3개 중 1개 Eee Pad Transformer Prime TF201 LED Chip Replacement: 2 단계, 이미지 3개 중 2개 Eee Pad Transformer Prime TF201 LED Chip Replacement: 2 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool into the seam near the corner of the device.
      • Slowly slide the tool around the perimeter of the device, gradually prying up the screen.
      • It is normal to hear snaps as the spring clips holding the screen in place are released.
      • It is also normal to hear adhesive separating, as a small amount is used to help secure the screen.
      댓글 쓰기
    3. Eee Pad Transformer Prime TF201 LED Chip Replacement: 3 단계, 이미지 3개 중 1개 Eee Pad Transformer Prime TF201 LED Chip Replacement: 3 단계, 이미지 3개 중 2개 Eee Pad Transformer Prime TF201 LED Chip Replacement: 3 단계, 이미지 3개 중 3개
      • When the screen is free of all spring clips and adhesive, slowly open the device like a clam shell with the hinge being the left hand side of the device.
      • Do not completely separate the screen from the case by more than a few inches, as they are still connected by three orange ribbon cables.
      • Safely place the device back on the table by laying the screen face down.
      • There will be some slight overlapping of the back of the case over the screen.
      댓글 쓰기
    4. Eee Pad Transformer Prime TF201 LED Chip Replacement: 4 단계, 이미지 2개 중 1개 Eee Pad Transformer Prime TF201 LED Chip Replacement: 4 단계, 이미지 2개 중 2개
      • Disconnect the ribbon cable by placing a plastic opening tool under the black plastic tab that is on the opposite side of the port as the ribbon cable.
      • Pry upward until the black tab moves 90 degrees, and gently pull the ribbon cable out of the port.
      댓글 쓰기
    5. Eee Pad Transformer Prime TF201 LED Chip Replacement: 5 단계, 이미지 1개 중 1개
      • Place a plastic opening tool under the white plastic tab on one of the ribbon cable ports.
      • Repeat the previous process to remove the other ribbon cable.
      댓글 쓰기
    6. Eee Pad Transformer Prime TF201 LED Chip Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
      • The device that we wrote this guide for did not come with a battery, so we cannot include it in our own guide steps.
      • The battery is removed during all repairs to protect against short circuits, shocks, and internal damage to the device.
      댓글 쓰기
    1. Eee Pad Transformer Prime TF201 LED Chip Replacement, LED Chip: 7 단계, 이미지 2개 중 1개 Eee Pad Transformer Prime TF201 LED Chip Replacement, LED Chip: 7 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • With a Phillips #00 screwdriver, remove the one 3.8 mm screw in the LED chip. The LED chip is a small green chip (about 1 square centimeter) located at the top center of the device.
      • Gently remove the chip with a pair of precision tweezers by grabbing the chip from one side, being careful not to pinch on a black piece of hardware on the chip.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Aaron Morland
회원 가입일: 10/06/16
346 평판
안내서 3개를 작성함
Cal Poly, Team 10-1, Livingston Fall 2016 Cal Poly, Team 10-1, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G1
2 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 35
전체 시간: 707
