주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Eightarc Fusion Button Replacement
필요한 것
  1. Eightarc Fusion Button Replacement, Buttons: 1 단계, 이미지 1개 중 1개
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface, or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65 mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
    댓글 쓰기
  2. Eightarc Fusion Button Replacement: 2 단계, 이미지 1개 중 1개
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
    댓글 쓰기
  3. Eightarc Fusion Button Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the clear rubber casing around the wire connector by lifting the casing up and moving it up along the wire.
    • Repeat for second clear rubber casing.
    댓글 쓰기
  4. Eightarc Fusion Button Replacement: 4 단계, 이미지 2개 중 1개 Eightarc Fusion Button Replacement: 4 단계, 이미지 2개 중 2개
    • Gently grasp and lift up on the metal section of the wire to remove the wire from the button connector.
    • A slight wiggling motion might help remove the wire from the connector.
    • Make sure to keep track of which wires go to what button slot location.
    댓글 쓰기
  5. Eightarc Fusion Button Replacement: 5 단계, 이미지 2개 중 1개 Eightarc Fusion Button Replacement: 5 단계, 이미지 2개 중 2개
    • Gently depress the two plastic tabs on both of the sides of the button casing.
    • The plastic tabs on the buttons are extremely fragile, handle with care.
    • Slightly push the button down, out of the controller until it slides out.
    • During re-assembly, make sure the button tabs align with the slots in the casing when inserting the button back in.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Austin
회원 가입일: 01/28/15
245 평판
안내서 2개를 작성함
Cal Poly, Team 17-35, Amido Winter 2015 Cal Poly, Team 17-35, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G35
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 37
전체 시간: 1,132
