주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Eightarc Fusion USB Cable Replacement
필요한 것
  1. Eightarc Fusion USB Cable Replacement, USB Cable: 1 단계, 이미지 2개 중 1개 Eightarc Fusion USB Cable Replacement, USB Cable: 1 단계, 이미지 2개 중 2개
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65 mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
    댓글 쓰기
  2. Eightarc Fusion USB Cable Replacement: 2 단계, 이미지 1개 중 1개
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
    댓글 쓰기
  3. Eightarc Fusion USB Cable Replacement: 3 단계, 이미지 1개 중 1개
    • With flap unlatched, gently bend the flap and pull slightly to get the pegs out of the socket
    • Be sure to be gentle and not snap the plastic flap in half.
    댓글 쓰기
  4. Eightarc Fusion USB Cable Replacement: 4 단계, 이미지 1개 중 1개
    • Slide USB cable up from the plastic barrier casing.
    댓글 쓰기
  5. Eightarc Fusion USB Cable Replacement: 5 단계, 이미지 3개 중 1개 Eightarc Fusion USB Cable Replacement: 5 단계, 이미지 3개 중 2개 Eightarc Fusion USB Cable Replacement: 5 단계, 이미지 3개 중 3개
    • The USB cord is connected to the logic board by a plastic plug with five wires.
    • Gently pull up and wiggle the white plastic end attached to the wires out of the mother board.
    • The white casing on top pulls off from its counterpart on the logic board. Do not take off the bottom part of the white fixture from the logic board.
    • Remove USB cable from device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Dana
회원 가입일: 02/01/15
141 평판
안내서 1개를 작성함
Cal Poly, Team 17-35, Amido Winter 2015 Cal Poly, Team 17-35, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G35
4 회원들
안내서 5개를 작성함
1가이드 댓글
Where do I get the USB wire?
desmond.bouey1 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 40
전체 시간: 1,233
