주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Electrohome EAAC475 USB Port Replacement
필요한 것
    1. Electrohome EAAC475 USB Port Replacement, Battery: 1 단계, 이미지 2개 중 1개 Electrohome EAAC475 USB Port Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Remove the 10 mm Phillips #1 screw from the battery cover.
      • Remove the battery cover.
      댓글 쓰기
    2. Electrohome EAAC475 USB Port Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the flat lithium battery.
      댓글 쓰기
    1. Electrohome EAAC475 USB Port Replacement, Buttons: 3 단계, 이미지 2개 중 1개 Electrohome EAAC475 USB Port Replacement, Buttons: 3 단계, 이미지 2개 중 2개
      • Disconnect the radio from all power sources.
      • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
      • Remove two 10 mm Phillips #1 screws from the back side of the device.
      댓글 쓰기
    2. Electrohome EAAC475 USB Port Replacement: 4 단계, 이미지 3개 중 1개 Electrohome EAAC475 USB Port Replacement: 4 단계, 이미지 3개 중 2개 Electrohome EAAC475 USB Port Replacement: 4 단계, 이미지 3개 중 3개
      • Carefully and slowly pull the lower case away from the rest of the device.
      • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
      • Flip the device over to access the button assembly.
      • Slowly remove the button contact board from the assembly.
      댓글 쓰기
    3. Electrohome EAAC475 USB Port Replacement: 5 단계, 이미지 2개 중 1개 Electrohome EAAC475 USB Port Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the two 7 mm Phillips # 1 screws holding the buttons.
      • Remove the plastic buttons.
      댓글 쓰기
    1. Electrohome EAAC475 USB Port Replacement, USB Port: 6 단계, 이미지 1개 중 1개
      • Locate the screw holding the USB circuit board in place.
      • Take a Philips head screwdriver and remove the 10 mm screw.
      댓글 쓰기
    2. Electrohome EAAC475 USB Port Replacement: 7 단계, 이미지 1개 중 1개
      • Upon removing the screw, the circuit board should slide right out to look like this.
      • The USB port is to the right in this picture.
      댓글 쓰기
    3. Electrohome EAAC475 USB Port Replacement: 8 단계, 이미지 1개 중 1개
      • Find the pins of the USB port that are soldered into the circuit board.
      • Compare the new port with the old port to be sure which pins to work with.
      • Take the soldering gun and heat up the pins one at a time.
      • If you are not familiar with soldering, consult a more skilled individual or at least a how-to guide.
      • Use solder wick with each pin to remove the solder.
      • Remove the USB port.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sterling Fulk
회원 가입일: 02/16/16
264 평판
안내서 2개를 작성함
IUPUI, Team 2-1, Harley Spring 2016 IUPUI, Team 2-1, Harley Spring 2016 회원
IUPUI-HARLEY-S16S2G1
4 회원들
안내서 48개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 25
전체 시간: 696
