주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Element GC-1020 Display Replacement
필요한 것
    1. Element GC-1020 Display Replacement, Back Cover Replacement Guide: 1 단계, 이미지 1개 중 1개
      • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
      댓글 쓰기
    2. Element GC-1020 Display Replacement: 2 단계, 이미지 1개 중 1개
      • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
      • If you pull back too forcefully the power button would move out of place.
      댓글 쓰기
    1. Element GC-1020 Display Replacement, Display: 3 단계, 이미지 1개 중 1개
      • Unscrew the visible Philips head screws (size: 3.968 mm) on the motherboard located on the top of left and right sides. Use a PH #0 sized screw driver head for removal.
      댓글 쓰기
    2. Element GC-1020 Display Replacement: 4 단계, 이미지 2개 중 1개 Element GC-1020 Display Replacement: 4 단계, 이미지 2개 중 2개
      • Carefully bend the plastic frame to remove the motherboard.
      • Upon doing this make sure your power button on the bottom left side stays attached to the outer frame because it will loosen as the motherboard is moved upwards.
      댓글 쓰기
    3. Element GC-1020 Display Replacement: 5 단계, 이미지 1개 중 1개
      • The display is attached to a dark yellow, flimsy, plastic material. This material is then attached to the motherboard. Tear off the plastic, successfully detaching the motherboard and display from each other.
      댓글 쓰기
    4. Element GC-1020 Display Replacement: 6 단계, 이미지 3개 중 1개 Element GC-1020 Display Replacement: 6 단계, 이미지 3개 중 2개 Element GC-1020 Display Replacement: 6 단계, 이미지 3개 중 3개
      • Once the display is by itself, separate from the rest of the device, you are ready to put in your new display.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Lashaun Noel
회원 가입일: 09/25/15
591 평판
안내서 5개를 작성함
University of Tampa, Team 1-4, Whiteside Fall 2015 University of Tampa, Team 1-4, Whiteside Fall 2015 회원
UT-WHITESIDE-F15S1G4
4 회원들
안내서 10개를 작성함
1가이드 댓글
but can i ask do you know how to reboot the software ?
i mean we try to put in our music or video or image inside. can it be done
Nisha Najihah - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 29
지난 30일: 53
전체 시간: 699
