주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ematic EGQ307 Digitizer Replacement
필요한 것
    1. Ematic EGQ307 Digitizer Replacement, Digitizer: 1 단계, 이미지 2개 중 1개 Ematic EGQ307 Digitizer Replacement, Digitizer: 1 단계, 이미지 2개 중 2개
      • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
      댓글 쓰기
    2. Ematic EGQ307 Digitizer Replacement: 2 단계, 이미지 2개 중 1개 Ematic EGQ307 Digitizer Replacement: 2 단계, 이미지 2개 중 2개
      • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
      • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
      댓글 쓰기
    3. Ematic EGQ307 Digitizer Replacement: 3 단계, 이미지 3개 중 1개 Ematic EGQ307 Digitizer Replacement: 3 단계, 이미지 3개 중 2개 Ematic EGQ307 Digitizer Replacement: 3 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • Once you pry off the plastic backing, you will expose the battery and the motherboard.
      • Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LCD.
      • Pry the battery off the LCD using a flat and rigid piece of plastic, such as the plastic card.
      댓글 쓰기
    4. Ematic EGQ307 Digitizer Replacement: 4 단계, 이미지 3개 중 1개 Ematic EGQ307 Digitizer Replacement: 4 단계, 이미지 3개 중 2개 Ematic EGQ307 Digitizer Replacement: 4 단계, 이미지 3개 중 3개
      • Carefully remove the tape holding the camera in place as the camera is attached to the backing of the tape.
      • Gently lift up the black lever that’s holding the camera ribbon in place using a long piece of stiff plastic.
      • Now, remove the camera from the device.
      댓글 쓰기
    5. Ematic EGQ307 Digitizer Replacement: 5 단계, 이미지 3개 중 1개 Ematic EGQ307 Digitizer Replacement: 5 단계, 이미지 3개 중 2개 Ematic EGQ307 Digitizer Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the three 2mm x 0.5mm screws with a Phillips #0 Screwdriver head from the motherboard.
      • Carefully remove the motherboard from the LCD backing. Remove tape from the edges of the LCD.
      • Carefully pry off the LCD with a piece of plastic.
      • Carefully remove the motherboard, battery, and the speaker, so wires do not get disconnected.
      댓글 쓰기
    6. Ematic EGQ307 Digitizer Replacement: 6 단계, 이미지 3개 중 1개 Ematic EGQ307 Digitizer Replacement: 6 단계, 이미지 3개 중 2개 Ematic EGQ307 Digitizer Replacement: 6 단계, 이미지 3개 중 3개
      • Now Protective Screen is removed and is ready to be replaced.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jonathan Scinto
회원 가입일: 07/21/15
530 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 24
전체 시간: 1,305
