주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ematic EGQ307 Front Facing Camera Replacement
필요한 것
    1. Ematic EGQ307 Front Facing Camera Replacement, Front Facing Camera: 1 단계, 이미지 1개 중 1개
      • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
      댓글 쓰기
    2. Ematic EGQ307 Front Facing Camera Replacement: 2 단계, 이미지 2개 중 1개 Ematic EGQ307 Front Facing Camera Replacement: 2 단계, 이미지 2개 중 2개
      • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
      • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
      댓글 쓰기
    3. Ematic EGQ307 Front Facing Camera Replacement: 3 단계, 이미지 1개 중 1개
      • Once you pry off the plastic backing, you will expose the battery and the motherboard.
      댓글 쓰기
    4. Ematic EGQ307 Front Facing Camera Replacement: 4 단계, 이미지 2개 중 1개 Ematic EGQ307 Front Facing Camera Replacement: 4 단계, 이미지 2개 중 2개
      • carefully pry off the plastic backing, remove the tape over the camera.
      • When working with device, make sure the battery is dead and there is not plugged in to the charger to limit the risk of shock.
      댓글 쓰기
    5. Ematic EGQ307 Front Facing Camera Replacement: 5 단계, 이미지 2개 중 1개 Ematic EGQ307 Front Facing Camera Replacement: 5 단계, 이미지 2개 중 2개
      • Carefully remove the tape holding the camera in place as the camera is attached to the backing of the tape.
      • Gently lift up the black lever that’s holding the camera ribbon in place using the spudger tools.
      • Once lever is lifted up, remove camera from device; and it is ready to be replaced.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Jonathan Scinto
회원 가입일: 07/21/15
530 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 32
전체 시간: 598
