주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ematic EGQ307 LCD Replacement
필요한 것
    1. Ematic EGQ307 LCD Replacement, LCD: 1 단계, 이미지 1개 중 1개
      • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
      댓글 쓰기
    2. Ematic EGQ307 LCD Replacement: 2 단계, 이미지 2개 중 1개 Ematic EGQ307 LCD Replacement: 2 단계, 이미지 2개 중 2개
      • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
      • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
      댓글 쓰기
    3. Ematic EGQ307 LCD Replacement: 3 단계, 이미지 3개 중 1개 Ematic EGQ307 LCD Replacement: 3 단계, 이미지 3개 중 2개 Ematic EGQ307 LCD Replacement: 3 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • Once you pry off the plastic backing, you will expose the battery and the motherboard.
      • Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LCD.
      • Pry the battery off the LCD using a flat and rigid piece of plastic, such as the plastic card.
      댓글 쓰기
    4. Ematic EGQ307 LCD Replacement: 4 단계, 이미지 3개 중 1개 Ematic EGQ307 LCD Replacement: 4 단계, 이미지 3개 중 2개 Ematic EGQ307 LCD Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the three 2mm x 0.5mm screws with a Phillips #0 Screwdriver head from the motherboard.
      • Carefully remove the motherboard from the LCD backing. Remove tape from the edges of the LCD.
      • Carefully pry off the LCD with the spudger.
      • Carefully remove the motherboard, battery, and the speaker, so wires do not get disconnected.
      댓글 쓰기
    5. Ematic EGQ307 LCD Replacement: 5 단계, 이미지 3개 중 1개 Ematic EGQ307 LCD Replacement: 5 단계, 이미지 3개 중 2개 Ematic EGQ307 LCD Replacement: 5 단계, 이미지 3개 중 3개
      • Now LCD is removed and is ready to be replaced.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order, note you will need to solder for this replacement.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jonathan Scinto
회원 가입일: 07/21/15
530 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 37
전체 시간: 1,551
