주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ematic Genesis Speaker Replacement
필요한 것
  1. Ematic Genesis Speaker Replacement, Ematic Genesis Casing: 1 단계, 이미지 3개 중 1개 Ematic Genesis Speaker Replacement, Ematic Genesis Casing: 1 단계, 이미지 3개 중 2개 Ematic Genesis Speaker Replacement, Ematic Genesis Casing: 1 단계, 이미지 3개 중 3개
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
    댓글 쓰기
  2. Ematic Genesis Speaker Replacement: 2 단계, 이미지 3개 중 1개 Ematic Genesis Speaker Replacement: 2 단계, 이미지 3개 중 2개 Ematic Genesis Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
    댓글 쓰기
  3. Ematic Genesis Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • Remove back plate from screen plate and lay both down flat next to each other.
    댓글 쓰기
  4. Ematic Genesis Speaker Replacement, Speaker: 4 단계, 이미지 1개 중 1개
    • Once panels are separated, disconnect speaker wires from motherboard.
    • Make sure device is completely turned off before doing this to avoid a potential electric shock.
    댓글 쓰기
  5. Ematic Genesis Speaker Replacement: 5 단계, 이미지 2개 중 1개 Ematic Genesis Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Insert the flat end of the spudger between the casing and the speaker. Push inwards to pry the speaker from the casing.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Justin Rohrman
회원 가입일: 03/23/15
745 평판
안내서 6개를 작성함
Baylor, Team 4-3, Williams Spring 2015 Baylor, Team 4-3, Williams Spring 2015 회원
BU-WILLIAMS-S15S4G3
3 회원들
안내서 12개를 작성함
1가이드 댓글
This help us alot, thanks for posting troubleshooting
wikirichard - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 20
전체 시간: 454
