주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Emerson Ceiling Fan Flywheel Replacement
필요한 것
  1. Emerson Ceiling Fan  Flywheel Replacement, Remove Ceiling Fan Blades: 1 단계, 이미지 3개 중 1개 Emerson Ceiling Fan  Flywheel Replacement, Remove Ceiling Fan Blades: 1 단계, 이미지 3개 중 2개 Emerson Ceiling Fan  Flywheel Replacement, Remove Ceiling Fan Blades: 1 단계, 이미지 3개 중 3개
    • Make sure power to the ceiling fan is off!
    • Use a Phillips #0 screwdriver to remove the ten 12.7 mm screws from the ceiling fan blades.
    • It is easier to work on the ceiling fan if you remove the motor.
    댓글 쓰기
  2. Emerson Ceiling Fan  Flywheel Replacement, Open Switch Housing: 2 단계, 이미지 2개 중 1개 Emerson Ceiling Fan  Flywheel Replacement, Open Switch Housing: 2 단계, 이미지 2개 중 2개
    • Remove light bulbs before working on switch housing.
    • Open the switch housing using a Phillips #0 screwdriver to remove the three 7.9 mm screws.
    댓글 쓰기
  3. Emerson Ceiling Fan  Flywheel Replacement, Disconnect Wires: 3 단계, 이미지 2개 중 1개 Emerson Ceiling Fan  Flywheel Replacement, Disconnect Wires: 3 단계, 이미지 2개 중 2개
    • Disconnect wires that are attached to the switch housing and the motor.
    • Make sure you know where to reconnect them.
    댓글 쓰기
  4. Emerson Ceiling Fan  Flywheel Replacement, Remove Broken Flywheel: 4 단계, 이미지 3개 중 1개 Emerson Ceiling Fan  Flywheel Replacement, Remove Broken Flywheel: 4 단계, 이미지 3개 중 2개 Emerson Ceiling Fan  Flywheel Replacement, Remove Broken Flywheel: 4 단계, 이미지 3개 중 3개
    • Remove the broken flywheel.
    • Make note of its exact placement on the shaft.
    • It may be a good idea to mark the location with a marker.
    댓글 쓰기
  5. Emerson Ceiling Fan  Flywheel Replacement, Attach New Flywheel: 5 단계, 이미지 3개 중 1개 Emerson Ceiling Fan  Flywheel Replacement, Attach New Flywheel: 5 단계, 이미지 3개 중 2개 Emerson Ceiling Fan  Flywheel Replacement, Attach New Flywheel: 5 단계, 이미지 3개 중 3개
    • Slide the new flywheel into place making sure all the holes line up.
    • Place any wires through the same holes as they were before
    • Replace any other parts you removed during the process.
    댓글 쓰기
  6. Emerson Ceiling Fan  Flywheel Replacement, Reconnect Wires: 6 단계, 이미지 2개 중 1개 Emerson Ceiling Fan  Flywheel Replacement, Reconnect Wires: 6 단계, 이미지 2개 중 2개
    • Reconnect the wires from the switch housing to the motor.
    • Make sure you connect the wires to the correct match.
    댓글 쓰기
  7. Emerson Ceiling Fan  Flywheel Replacement, Close Switch Housing: 7 단계, 이미지 3개 중 1개 Emerson Ceiling Fan  Flywheel Replacement, Close Switch Housing: 7 단계, 이미지 3개 중 2개 Emerson Ceiling Fan  Flywheel Replacement, Close Switch Housing: 7 단계, 이미지 3개 중 3개
    • Screw back on the three 7.9 mm screws to the switch housing using a Phillips #0 screwdriver.
    • Screw the light bulbs back in.
    댓글 쓰기
  8. Emerson Ceiling Fan  Flywheel Replacement, Reconnect Ceiling Fan Blades: 8 단계, 이미지 3개 중 1개 Emerson Ceiling Fan  Flywheel Replacement, Reconnect Ceiling Fan Blades: 8 단계, 이미지 3개 중 2개 Emerson Ceiling Fan  Flywheel Replacement, Reconnect Ceiling Fan Blades: 8 단계, 이미지 3개 중 3개
    • Using a Phillips #0 screwdriver, reconnect ceiling fan blades by re-screwing on ten 12.7 mm Phillip screws.
    • If you removed the motor, reconnect it after blades are on.
    댓글 쓰기
결론
Test your fan. It should be running quietly with no problems. If something is wrong make sure to double check you hooked the wires up correctly.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Tanner Brook
회원 가입일: 10/21/19
199 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 66
전체 시간: 5,204
