주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Enabot EBO SE Camera Replacement
필요한 것
  1. Enabot EBO SE Camera Replacement, Wheel Assembly: 1 단계, 이미지 1개 중 1개
    • Gently turn the robot upside down.
    • Place the robot on a stable surface to prevent it from rolling or falling.
    댓글 쓰기
  2. Enabot EBO SE Camera Replacement: 2 단계, 이미지 3개 중 1개 Enabot EBO SE Camera Replacement: 2 단계, 이미지 3개 중 2개 Enabot EBO SE Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Use a flathead 2.5 mm screwdriver to remove the 5.7 mm screw from the wheels.
    • A tool should have been provided in the box for this purpose.
    댓글 쓰기
  3. Enabot EBO SE Camera Replacement: 3 단계, 이미지 2개 중 1개 Enabot EBO SE Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the wheel assembly towards you so it comes straight off without resistance.
    • If there is resistance, make sure to apply gentle force when pulling as it can get damaged with too much force.
    댓글 쓰기
  4. Enabot EBO SE Camera Replacement, Lower Housing: 4 단계, 이미지 2개 중 1개 Enabot EBO SE Camera Replacement, Lower Housing: 4 단계, 이미지 2개 중 2개
    • Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
    댓글 쓰기
  5. Enabot EBO SE Camera Replacement: 5 단계, 이미지 3개 중 1개 Enabot EBO SE Camera Replacement: 5 단계, 이미지 3개 중 2개 Enabot EBO SE Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Use your fingernail to carefully press down and eject the Micro SD Card from the back of the Enabot.
    • Keep the Micro SD Card in a safe spot for later.
    댓글 쓰기
  6. Enabot EBO SE Camera Replacement: 6 단계, 이미지 2개 중 1개 Enabot EBO SE Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Place the iFixit opening tool inside the Micro SD slot.
    • Very carefully apply pressure to the top of the slot and pry open the casing to separate the upper and lower housing.
    댓글 쓰기
  7. Enabot EBO SE Camera Replacement: 7 단계, 이미지 3개 중 1개 Enabot EBO SE Camera Replacement: 7 단계, 이미지 3개 중 2개 Enabot EBO SE Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Using the iFixit opening tool or your fingernail, place it underneath the gray tab on the lower housing.
    • Lift the tab up and pull out the ribbon cable to disconnect it from the lower housing.
    댓글 쓰기
  8. Enabot EBO SE Camera Replacement: 8 단계, 이미지 3개 중 1개 Enabot EBO SE Camera Replacement: 8 단계, 이미지 3개 중 2개 Enabot EBO SE Camera Replacement: 8 단계, 이미지 3개 중 3개
    • There are two black and red wire connectors attached to the upper and lower housing.
    • Gently use your finger nails to lift up and disconnect both wires to fully separate the upper and lower housings.
    댓글 쓰기
  9. Enabot EBO SE Camera Replacement, Motherboard: 9 단계, 이미지 2개 중 1개 Enabot EBO SE Camera Replacement, Motherboard: 9 단계, 이미지 2개 중 2개
    • Use the iFixit opening tool to unlock the side gray tab and free the orange & black ribbon cable.
    댓글 쓰기
  10. Enabot EBO SE Camera Replacement: 10 단계, 이미지 2개 중 1개 Enabot EBO SE Camera Replacement: 10 단계, 이미지 2개 중 2개
    • Use the iFixit opening tool to unlock the middle gray tab and free the orange & black ribbon cable.
    댓글 쓰기
  11. Enabot EBO SE Camera Replacement: 11 단계, 이미지 3개 중 1개 Enabot EBO SE Camera Replacement: 11 단계, 이미지 3개 중 2개 Enabot EBO SE Camera Replacement: 11 단계, 이미지 3개 중 3개
    • Select one of the release tabs on the edge of the upper casing that holds the motherboard in place.
    • Place one finger in between the motherboard and the upper casing.
    • Pull the release tab back while lifting the motherboard with your other finger to "pop" the motherboard out of the casing.
    댓글 쓰기
  12. Enabot EBO SE Camera Replacement: 12 단계, 이미지 3개 중 1개 Enabot EBO SE Camera Replacement: 12 단계, 이미지 3개 중 2개 Enabot EBO SE Camera Replacement: 12 단계, 이미지 3개 중 3개
    • Use the ifixit opening tool to disconnect the blue & white ribbon cable.
    • Gently pull the blue & white ribbon cable out of the gray connector tab.
    댓글 쓰기
  13. Enabot EBO SE Camera Replacement, Camera: 13 단계, 이미지 3개 중 1개 Enabot EBO SE Camera Replacement, Camera: 13 단계, 이미지 3개 중 2개 Enabot EBO SE Camera Replacement, Camera: 13 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove all five 7.4 mm screws from the upper casing.
    댓글 쓰기
  14. Enabot EBO SE Camera Replacement: 14 단계, 이미지 2개 중 1개 Enabot EBO SE Camera Replacement: 14 단계, 이미지 2개 중 2개
    • Place your fingers in the space between the black casing and white lid.
    • Pull black casing towards you to separate the two parts.
    댓글 쓰기
  15. Enabot EBO SE Camera Replacement: 15 단계, 이미지 3개 중 1개 Enabot EBO SE Camera Replacement: 15 단계, 이미지 3개 중 2개 Enabot EBO SE Camera Replacement: 15 단계, 이미지 3개 중 3개
    • Remove the two 6 mm Phillips #00 screws on either side of the camera.
    댓글 쓰기
  16. Enabot EBO SE Camera Replacement: 16 단계, 이미지 3개 중 1개 Enabot EBO SE Camera Replacement: 16 단계, 이미지 3개 중 2개 Enabot EBO SE Camera Replacement: 16 단계, 이미지 3개 중 3개
    • Gently remove the camera until it comes out of the casing.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Oscar Parra
회원 가입일: 02/16/24
109 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 39
전체 시간: 624
