주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Epson PPC650 Camera Case Replacement
필요한 것
    1. Epson PPC650 Camera Case Replacement, Case: 1 단계, 이미지 3개 중 1개 Epson PPC650 Camera Case Replacement, Case: 1 단계, 이미지 3개 중 2개 Epson PPC650 Camera Case Replacement, Case: 1 단계, 이미지 3개 중 3개
      • Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
      • Remove the batteries from the battery compartment located on the underside of the camera.
      • Remove the SD card from the compartment located on the flat, left side of the camera.
      댓글 쓰기
    2. Epson PPC650 Camera Case Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the two screws on the rounded side of the camera.
      댓글 쓰기
    3. Epson PPC650 Camera Case Replacement: 3 단계, 이미지 2개 중 1개 Epson PPC650 Camera Case Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the three screws on the flat side of the camera.
      • All of the silver screws go into the side of the camera that is silver.
      • All of the black screws go into the side of the camera that is black.
      댓글 쓰기
    4. Epson PPC650 Camera Case Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the four screws from the bottom of the camera.
      댓글 쓰기
    5. Epson PPC650 Camera Case Replacement: 5 단계, 이미지 3개 중 1개 Epson PPC650 Camera Case Replacement: 5 단계, 이미지 3개 중 2개 Epson PPC650 Camera Case Replacement: 5 단계, 이미지 3개 중 3개
      • Separate the front and the back pieces of the camera's plastic casing using a spudger.
      • WARNING: When pulling the front plastic casing, be careful of the wires that are connected to the aperture control.
      • Use minimal force so that the plastic casing does not break.
      • When separating the small silver siding, the indicator for the view/off/playback may fall out.
      • The plastic viewing window located on the top of the camera may also become lose and fall out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Brittany
회원 가입일: 02/12/13
113 평판
안내서 1개를 작성함
Ohio State, Team 1-5, Buehl Spring 2013 Ohio State, Team 1-5, Buehl Spring 2013 회원
OSU-BUEHL-S13S1G5
4 회원들
안내서 33개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 35
전체 시간: 626
