주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Epson PowerLite 77c Fan Replacement
필요한 것
  1. Epson PowerLite 77c Fan Replacement, Lamp: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the one 5.0 mm screw from the lamp cover on the back of the device.
    댓글 쓰기
  2. Epson PowerLite 77c Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the cover toward you, then lift it to remove it.
    댓글 쓰기
  3. Epson PowerLite 77c Fan Replacement: 3 단계, 이미지 2개 중 1개 Epson PowerLite 77c Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Loosen the two 5.0 mm captive screws with a Phillips #0 screwdriver.
    • Captive screws cannot be fully removed. Simply loosen the captive screws until the lamp housing releases, but do not attempt to remove them.
    • Pinch the two release triggers to unlatch the lamp housing, and lift upward to remove it.
    댓글 쓰기
  4. Epson PowerLite 77c Fan Replacement, Fan: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
    • Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
    • Lift the top panel up.
    • Two connectors are holding the top panel to the motherboard; be careful not to damage them as you lift the top panel.
    댓글 쓰기
  5. Epson PowerLite 77c Fan Replacement: 5 단계, 이미지 2개 중 1개 Epson PowerLite 77c Fan Replacement: 5 단계, 이미지 2개 중 2개
    • Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
    • Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
    • Remove the top panel.
    댓글 쓰기
  6. Epson PowerLite 77c Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the two 5.0 mm screws.
    댓글 쓰기
  7. Epson PowerLite 77c Fan Replacement: 7 단계, 이미지 2개 중 1개 Epson PowerLite 77c Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the one 5.0 mm screw on the right side of the gap with a Phillips #0 screwdriver.
    • Remove the one 5.0 mm screw on the left side of the gap with a Phillips #0 screwdriver.
    댓글 쓰기
  8. Epson PowerLite 77c Fan Replacement: 8 단계, 이미지 1개 중 1개
    • On the right side of the motherboard, grip the plug labeled "PWR-FAN" and pull straight up to detach the fan from the motherboard.
    댓글 쓰기
  9. Epson PowerLite 77c Fan Replacement: 9 단계, 이미지 2개 중 1개 Epson PowerLite 77c Fan Replacement: 9 단계, 이미지 2개 중 2개
    • Grip the fan and lift it up and out.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Xandher Thao
회원 가입일: 02/08/22
161 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 16
전체 시간: 378
