주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Epson Stylus NX305 Scanner Motor Replacement
필요한 것
    1. Epson Stylus NX305 Scanner Motor Replacement, Scanner Motor: 1 단계, 이미지 1개 중 1개
      • Make sure that the printer is not plugged in before working on it.
      • Orient the printer so that the back of it is facing you.
      댓글 쓰기
    2. Epson Stylus NX305 Scanner Motor Replacement: 2 단계, 이미지 1개 중 1개
      • Locate the 3mm Phillips #0 screw that is on the right-hand side of the printer.
      • Using a Phillips head screwdriver, remove the screw.
      댓글 쓰기
    3. Epson Stylus NX305 Scanner Motor Replacement: 3 단계, 이미지 2개 중 1개 Epson Stylus NX305 Scanner Motor Replacement: 3 단계, 이미지 2개 중 2개
      • Open up the lid of the printer.
      • With the printer facing away from you, lift up on the right hand side of the lid of the printer and slide it to the left to remove it.
      • Be careful not to remove the white ribbon and wires that are connected.
      댓글 쓰기
    4. Epson Stylus NX305 Scanner Motor Replacement: 4 단계, 이미지 1개 중 1개
      • With the printer facing you, open the lid of the scanner to expose the 3mm Phillips #0 screw at the top left of the scanner.
      댓글 쓰기
    5. Epson Stylus NX305 Scanner Motor Replacement: 5 단계, 이미지 1개 중 1개
      • Locate the six 3mm Phillips #2 screws under the lid of the printer and remove them.
      댓글 쓰기
    6. Epson Stylus NX305 Scanner Motor Replacement: 6 단계, 이미지 1개 중 1개
      • Locate the three clips on the front side of the printer lid.
      • Use the plastic opening tool to release the clips and carefully pry open the lid.
      댓글 쓰기
    7. Epson Stylus NX305 Scanner Motor Replacement: 7 단계, 이미지 1개 중 1개
      • Locate the belt that is attached to the scanner motor and remove it by carefully stretching off of the gear.
      댓글 쓰기
    8. Epson Stylus NX305 Scanner Motor Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the two 3mm Phillips #2 screws from the scanner motor assembly.
      • Carefully lift the scanner motor assembly out of the housing making sure not to damage the wiring.
      댓글 쓰기
    9. Epson Stylus NX305 Scanner Motor Replacement: 9 단계, 이미지 1개 중 1개
      • Flip over the scanner motor assembly to expose the scanner motor.
      • Remove the two 3mm Phillips #2 screws from the assembly and remove the motor.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Jeffrey Barnett
회원 가입일: 09/21/14
101 평판
안내서 1개를 작성함
USF Tampa, Team 1-2, Donnelly Fall 2014 USF Tampa, Team 1-2, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G2
1 회원
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 29
전체 시간: 784
