주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Epson VS240 Bulb Replacement
필요한 것
    1. Epson VS240 Bulb Replacement, Bulb: 1 단계, 이미지 2개 중 1개 Epson VS240 Bulb Replacement, Bulb: 1 단계, 이미지 2개 중 2개
      • Unplug the device and let it cool for an hour.
      • Place the device on a flat surface.
      댓글 쓰기
    2. Epson VS240 Bulb Replacement: 2 단계, 이미지 2개 중 1개 Epson VS240 Bulb Replacement: 2 단계, 이미지 2개 중 2개
      • Using the Phillips #2 screwdriver, loosen the single screw securing the lamp cover.
      • Be careful of broken glass in the case that your bulb has been broken.
      • If there is broken glass, carefully shake the device to get the shards of glass on a piece of paper. Carefully dispose of the paper with the glass shards on it.
      댓글 쓰기
    3. Epson VS240 Bulb Replacement: 3 단계, 이미지 2개 중 1개 Epson VS240 Bulb Replacement: 3 단계, 이미지 2개 중 2개
      • Carefully slide the cover and lift it off the device.
      • Again, be careful of any broken parts within the device.
      댓글 쓰기
    4. Epson VS240 Bulb Replacement: 4 단계, 이미지 3개 중 1개 Epson VS240 Bulb Replacement: 4 단계, 이미지 3개 중 2개 Epson VS240 Bulb Replacement: 4 단계, 이미지 3개 중 3개
      • Use the Phillips #2 screwdriver to loosen the screws attaching the bulb to the projector.
      • You only need to loosen the screws since they do not remove from the bulb completely.
      댓글 쓰기
    5. Epson VS240 Bulb Replacement: 5 단계, 이미지 2개 중 1개 Epson VS240 Bulb Replacement: 5 단계, 이미지 2개 중 2개
      • Once the bulb has been loosened, grab the raised section of the bulb and carefully lift the bulb up and away from the device.
      댓글 쓰기
결론
Be gentle when inserting the new bulb. If you feel any resistance when inserting the replacement bulb, chances are that you inserted it the wrong way. This is a common mistake. Turn it around, making it face the right direction, before again inserting it into the device.
Be careful when screwing components back into the device since over-screwing can result in damage to the pieces.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Toni Brennan
회원 가입일: 09/28/21
121 평판
안내서 1개를 작성함
Clemson, Team 5-3, Hunter Fall 2021 Clemson, Team 5-3, Hunter Fall 2021 회원
CLEM-HUNTER-F21S5G3
5 회원들
안내서 18개를 작성함
1가이드 댓글
I replaced the bulb in the projector, but it still won't operate, and when I removed and reinstalled a bulb in my other projector, it does the same thing now, How do I fix it even with a replacement bulb?
Derrick A Durham - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 21
전체 시간: 637
