주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Epson VS250 Fan Replacement
필요한 것
    1. Epson VS250 Fan Replacement, Shell: 1 단계, 이미지 1개 중 1개
      • Place the projector on a flat surface.
      • Orient the projector so that the the word "Epson" is facing you.
      • Using the Phillips #1 screwdriver, to loosen the screw on the top right corner of the projector. The screw only needs to be loosened.
      댓글 쓰기
    2. Epson VS250 Fan Replacement: 2 단계, 이미지 1개 중 1개
      • Slide the cover to the right and lift the cover up and out to remove.
      댓글 쓰기
    3. Epson VS250 Fan Replacement: 3 단계, 이미지 1개 중 1개
      • Using a Phillips #1 screwdriver, remove the three 6 mm screws that hold the side portion of the projector in place.
      • Use the same Phillips #1 screwdriver to remove the single 10 mm screw that is holding the side cover of the projector in place.
      댓글 쓰기
    4. Epson VS250 Fan Replacement: 4 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to remove the two 10 mm screws that are holding the side cover of the projector in place.
      댓글 쓰기
    5. Epson VS250 Fan Replacement: 5 단계, 이미지 2개 중 1개 Epson VS250 Fan Replacement: 5 단계, 이미지 2개 중 2개
      • Flip the projector so that it lays upside down.
      • Using a Phillips #1 screwdriver, remove the eight 10 mm screws that secure the side portion of the projector.
      댓글 쓰기
    6. Epson VS250 Fan Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the front cover from the projector by pulling it off of the device.
      댓글 쓰기
    7. Epson VS250 Fan Replacement: 7 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to remove the two 10 mm screws.
      • After completing this step you will be able to remove the back cover from the projector.
      댓글 쓰기
    8. Epson VS250 Fan Replacement: 8 단계, 이미지 1개 중 1개
      • Slowly lift up the top shell up and out of the device.
      • Disconnect the ribbon cable from the motherboard and remove the shell from the device.
      댓글 쓰기
    1. Epson VS250 Fan Replacement, Fan: 9 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to remove the five 10 mm screws.
      댓글 쓰기
    2. Epson VS250 Fan Replacement: 10 단계, 이미지 3개 중 1개 Epson VS250 Fan Replacement: 10 단계, 이미지 3개 중 2개 Epson VS250 Fan Replacement: 10 단계, 이미지 3개 중 3개
      • Unplug the fan connector from the circuit board.
      • Remove the wires from the hooks that secure them to free the fan.
      댓글 쓰기
    3. Epson VS250 Fan Replacement: 11 단계, 이미지 2개 중 1개 Epson VS250 Fan Replacement: 11 단계, 이미지 2개 중 2개
      • Disconnect the wire and remove the black casing from the rest of the fan assembly.
      댓글 쓰기
    4. Epson VS250 Fan Replacement: 12 단계, 이미지 2개 중 1개 Epson VS250 Fan Replacement: 12 단계, 이미지 2개 중 2개
      • Remove the fan from the device.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Warren Cutlip
회원 가입일: 09/28/21
604 평판
안내서 5개를 작성함
Clemson, Team 4-2, Hunter Fall 2021 Clemson, Team 4-2, Hunter Fall 2021 회원
CLEM-HUNTER-F21S4G2
5 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 26
전체 시간: 740
