주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Esteban Crystal Heart Strings Replacement
필요한 것
    1. Esteban Crystal Heart Strings Replacement, Removing the damaged strings from the head: 1 단계, 이미지 3개 중 1개 Esteban Crystal Heart Strings Replacement, Removing the damaged strings from the head: 1 단계, 이미지 3개 중 2개 Esteban Crystal Heart Strings Replacement, Removing the damaged strings from the head: 1 단계, 이미지 3개 중 3개
      • On the head of the guitar, unroll the string from its tuning peg.
      • Once the string is unrolled, remove the string by sliding it out of the small hole in its tuning peg.
      댓글 쓰기
    2. Esteban Crystal Heart Strings Replacement, Removing the string from the bridge: 2 단계, 이미지 3개 중 1개 Esteban Crystal Heart Strings Replacement, Removing the string from the bridge: 2 단계, 이미지 3개 중 2개 Esteban Crystal Heart Strings Replacement, Removing the string from the bridge: 2 단계, 이미지 3개 중 3개
      • Remove the peg from the bridge but pulling it out of its hole.
      • Pull the string out of the hole.
      댓글 쓰기
    3. Esteban Crystal Heart Strings Replacement, Inserting the new string on the bridge.: 3 단계, 이미지 3개 중 1개 Esteban Crystal Heart Strings Replacement, Inserting the new string on the bridge.: 3 단계, 이미지 3개 중 2개 Esteban Crystal Heart Strings Replacement, Inserting the new string on the bridge.: 3 단계, 이미지 3개 중 3개
      • Insert the end of the string with the small hole in it in the opened peg in the bridge.
      • Start to insert the peg in the hole with the string under it.
      • Push the peg down tightly to make sure that the string will not pop out when enough resistance is put in it.
      댓글 쓰기
    4. Esteban Crystal Heart Strings Replacement, Inserting the new string in the head: 4 단계, 이미지 3개 중 1개 Esteban Crystal Heart Strings Replacement, Inserting the new string in the head: 4 단계, 이미지 3개 중 2개 Esteban Crystal Heart Strings Replacement, Inserting the new string in the head: 4 단계, 이미지 3개 중 3개
      • Pull the string and line it around the tuning peg, underneath the hole. Make sure that the resistance is pretty strong.
      • Wrap the remaining strings on the tuning peg about 5 or 6 times.
      • Slide the remaining end of the string through the hole and hold it in place.
      댓글 쓰기
    5. Esteban Crystal Heart Strings Replacement, Tightening the string: 5 단계, 이미지 3개 중 1개 Esteban Crystal Heart Strings Replacement, Tightening the string: 5 단계, 이미지 3개 중 2개 Esteban Crystal Heart Strings Replacement, Tightening the string: 5 단계, 이미지 3개 중 3개
      • Twist the tuning peg to the right to tighten it.
      • Make sure that the string has enough resistance that when it is strummed, there is a tone.
      댓글 쓰기
    6. Esteban Crystal Heart Strings Replacement, Tuning the guitar in its correct sound: 6 단계, 이미지 3개 중 1개 Esteban Crystal Heart Strings Replacement, Tuning the guitar in its correct sound: 6 단계, 이미지 3개 중 2개 Esteban Crystal Heart Strings Replacement, Tuning the guitar in its correct sound: 6 단계, 이미지 3개 중 3개
      • You can use a tuner by just playing each string in front of it and then just turn the fasteners until the tuner shows that the sound matches its appropriate sound.
      • Another way is by ear, press down on the fifth fret and the preceding string in which you are trying to tune. For example, if you are tuning the high E string, press down the B string, 5th fret.
      • Strumming the B stringwhile pressing down on the 5th fret should make the sound of open E string.
      • Match the sounds of both strings and this will tune the high E string.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Andrew Jayson Caberto
회원 가입일: 10/11/14
143 평판
안내서 1개를 작성함
USF Tampa, Team 1-5, Donnelly Fall 2014 USF Tampa, Team 1-5, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G5
1 회원
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 39
전체 시간: 1,545
