주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Eton FRX3 Rechargeable Battery Pack Replacement
    1. Eton FRX3 Rechargeable Battery Pack Replacement, Rechargeable Battery Pack: 1 단계, 이미지 1개 중 1개
      • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
      댓글 쓰기
    2. Eton FRX3 Rechargeable Battery Pack Replacement: 2 단계, 이미지 1개 중 1개
      • Disconnect the battery pack wires from the device and remove the battery pack.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in the reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kenneth Sills
회원 가입일: 02/10/16
762 평판
안내서 6개를 작성함
USF Tampa, Team 1-6, Nance Spring 2016 USF Tampa, Team 1-6, Nance Spring 2016 회원
USFT-NANCE-S16S1G6
4 회원들
안내서 104개를 작성함
4가이드 댓글
My question is where can you find an FRX3 replacement battery?
jalwitt - 답글 공유
Hey mate, you can buy the battery packs from a number of sources. Here's the link to one of those sources https://www.amazon.com/HQRP-FR200-BAT-3A...
james - 답글 공유
is it ok to replace it with a higher capacity lithium battery?
troydeleon - 답글 공유
As long as the specifications match, that should be fine. Just be careful when swapping out components in circuits, as it can potentially destroy the device if they're incompatible!
Kenneth Sills - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 84
전체 시간: 6,696
