주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Eton FRX3 Volume Dial Replacement
필요한 것
  1. Eton FRX3 Volume Dial Replacement, Rechargeable Battery Pack: 1 단계, 이미지 1개 중 1개
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
    댓글 쓰기
  2. Eton FRX3 Volume Dial Replacement: 2 단계, 이미지 1개 중 1개
    • Disconnect the battery pack wires from the device and remove the battery pack.
    댓글 쓰기
  3. Eton FRX3 Volume Dial Replacement, Case Assembly: 3 단계, 이미지 1개 중 1개
    • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
    댓글 쓰기
  4. Eton FRX3 Volume Dial Replacement: 4 단계, 이미지 1개 중 1개
    • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
    댓글 쓰기
  5. Eton FRX3 Volume Dial Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the two Phillips #00 screws located in the center of the back of the device.
    • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
    댓글 쓰기
  6. Eton FRX3 Volume Dial Replacement: 6 단계, 이미지 1개 중 1개
    • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
    • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
    댓글 쓰기
  7. Eton FRX3 Volume Dial Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the two halves of the device's case apart.
    • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
    댓글 쓰기
  8. Eton FRX3 Volume Dial Replacement, Volume Dial: 8 단계, 이미지 1개 중 1개
    • Unplug the socket connection from the I/O board as shown in the image.
    댓글 쓰기
  9. Eton FRX3 Volume Dial Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the two 1 cm Philips #0 screws that secure the tuning dial panel to the device case.
    댓글 쓰기
  10. Eton FRX3 Volume Dial Replacement: 10 단계, 이미지 1개 중 1개
    • Gently lift the dial upwards to remove it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jose Mendieta
회원 가입일: 02/10/16
255 평판
안내서 2개를 작성함
USF Tampa, Team 1-6, Nance Spring 2016 USF Tampa, Team 1-6, Nance Spring 2016 회원
USFT-NANCE-S16S1G6
4 회원들
안내서 26개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 34
전체 시간: 888
