주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Eureka 1660SP Extendable Pole Realignment
필요한 것
    1. Eureka 1660SP Extendable Pole Realignment, Motor Housing: 1 단계, 이미지 2개 중 1개 Eureka 1660SP Extendable Pole Realignment, Motor Housing: 1 단계, 이미지 2개 중 2개
      • Before you start, make sure your vacuum is unplugged the power outlet.
      • Press and hold down the black button below the handle while pulling the pole out.
      댓글 쓰기
    2. Eureka 1660SP Extendable Pole Realignment: 2 단계, 이미지 2개 중 1개 Eureka 1660SP Extendable Pole Realignment: 2 단계, 이미지 2개 중 2개
      • Press the black separator switch to separate the top and bottom halves of the vacuum.
      댓글 쓰기
    3. Eureka 1660SP Extendable Pole Realignment: 3 단계, 이미지 3개 중 1개 Eureka 1660SP Extendable Pole Realignment: 3 단계, 이미지 3개 중 2개 Eureka 1660SP Extendable Pole Realignment: 3 단계, 이미지 3개 중 3개
      • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
      • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
      • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
      댓글 쓰기
    1. Eureka 1660SP Extendable Pole Realignment, Realignment of the extendable pole: 4 단계, 이미지 1개 중 1개
      • Once the housing is open, locate the solid chrome plated piece at the front end of the extendable pole.
      댓글 쓰기
    2. Eureka 1660SP Extendable Pole Realignment: 5 단계, 이미지 2개 중 1개 Eureka 1660SP Extendable Pole Realignment: 5 단계, 이미지 2개 중 2개
      • On the side of the motor housing which does not hold the engine, find the center track which runs along the inside of the housing.
      • Re-insert the chrome plated piece into the center track.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Evan Fodi
회원 가입일: 09/24/13
122 평판
안내서 2개를 작성함
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 회원
UMASSD-GULBRANDSEN-F13S1G1
3 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 27
전체 시간: 836
