주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Eureka 1660SP External Start Switch Realignment
필요한 것
    1. Eureka 1660SP External Start Switch Realignment, Motor Housing: 1 단계, 이미지 2개 중 1개 Eureka 1660SP External Start Switch Realignment, Motor Housing: 1 단계, 이미지 2개 중 2개
      • Before you start, make sure your vacuum is unplugged the power outlet.
      • Press and hold down the black button below the handle while pulling the pole out.
      댓글 쓰기
    2. Eureka 1660SP External Start Switch Realignment: 2 단계, 이미지 2개 중 1개 Eureka 1660SP External Start Switch Realignment: 2 단계, 이미지 2개 중 2개
      • Press the black separator switch to separate the top and bottom halves of the vacuum.
      댓글 쓰기
    3. Eureka 1660SP External Start Switch Realignment: 3 단계, 이미지 3개 중 1개 Eureka 1660SP External Start Switch Realignment: 3 단계, 이미지 3개 중 2개 Eureka 1660SP External Start Switch Realignment: 3 단계, 이미지 3개 중 3개
      • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
      • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
      • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
      댓글 쓰기
    1. Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: 4 단계, 이미지 3개 중 1개 Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: 4 단계, 이미지 3개 중 2개 Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: 4 단계, 이미지 3개 중 3개
      • If the external switch is slightly misaligned as shown, realign it with the internal switch.
      • Make sure the spring loaded button on the underside of the housing is intact when reassembling the motor housing. It is prone to eject when opening the motor housing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Evan Fodi
회원 가입일: 09/24/13
122 평판
안내서 2개를 작성함
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 회원
UMASSD-GULBRANDSEN-F13S1G1
3 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 21
전체 시간: 2,784
