주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Evercade EXP Screen Replacement
필요한 것
  1. Evercade EXP Screen Replacement, Faceplate: 1 단계, 이미지 3개 중 1개 Evercade EXP Screen Replacement, Faceplate: 1 단계, 이미지 3개 중 2개 Evercade EXP Screen Replacement, Faceplate: 1 단계, 이미지 3개 중 3개
    • Lay the device on a flat surface, with the screen facing the sufrace.
    • Using angled tweezers, remove the six rubber screw covers from the sockets.
    • The covers are all identical, so they do not need to be stored separately from one another.
    댓글 쓰기
  2. Evercade EXP Screen Replacement: 2 단계, 이미지 3개 중 1개 Evercade EXP Screen Replacement: 2 단계, 이미지 3개 중 2개 Evercade EXP Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Using a Phillips #00 screwdriver, remove the six 8 mm screws on the lower case.
    댓글 쓰기
  3. Evercade EXP Screen Replacement: 3 단계, 이미지 2개 중 1개 Evercade EXP Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Flip the device so the screen is facing you.
    • Four hidden retaining clips hold the pieces together even near each corner of the screen.
    • Insert a Jimmy into the seam located between the faceplate and the shell.
    • Move the a Jimmy toward the screen until you find the first clasp. Move the handle of the jimmy tool up to pop the faceplate free from the clasp.
    • Repeat until for each of the four clasps to fully release the faceplate from the shell.
    • Do not use excessive force when moving the Jimmy. The plastic may shear if too much force is applied horizontally, and it may snap if too much vertical force is applied.
    댓글 쓰기
  4. Evercade EXP Screen Replacement: 4 단계, 이미지 3개 중 1개 Evercade EXP Screen Replacement: 4 단계, 이미지 3개 중 2개 Evercade EXP Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Flip the faceplate away from the shell carefully. The faceplate is still connected to the motherboard via a ribbon cable.
    • Flip up the locking flap securing the display ribbon cable, then use tweezers to disconnect the ribbon cable.
    • Be careful when separating the faceplate from the shell, the buttons are held in place by the connection, so they may fall out when opening the device.
    댓글 쓰기
  5. Evercade EXP Screen Replacement, Screen: 5 단계, 이미지 3개 중 1개 Evercade EXP Screen Replacement, Screen: 5 단계, 이미지 3개 중 2개 Evercade EXP Screen Replacement, Screen: 5 단계, 이미지 3개 중 3개
    • The screen is attached with a double-sided adhesive. When removing the screen make sure the work area is clean to prevent smudges on the interior of the screen.
    • To remove the display from the screen, insert a spudger into the gap between the screen and display at the corner.
    • Slowly move the spudger along the seam until you reach the opposite corner.
    • Use your hand to gently pull the screen away from the display which will break the adhesive seal.
    • Be careful when removing the display because it is fragile that metal tools will easily crack or scratch the glass.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Ariana Travis
회원 가입일: 02/03/26
295 평판
안내서 2개를 작성함
Utah Tech University, Team 1-6, McMurrin Spring 2026 Utah Tech University, Team 1-6, McMurrin Spring 2026 회원
UTAHTECH-MCMURRIN-S26S1G6
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 29
전체 시간: 45
