주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ExoPC Slate CPU Fan Replacement
필요한 것
    1. ExoPC Slate CPU Fan Replacement, Back Cover and Shield: 1 단계, 이미지 2개 중 1개 ExoPC Slate CPU Fan Replacement, Back Cover and Shield: 1 단계, 이미지 2개 중 2개
      • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
      댓글 쓰기
    2. ExoPC Slate CPU Fan Replacement: 2 단계, 이미지 2개 중 1개 ExoPC Slate CPU Fan Replacement: 2 단계, 이미지 2개 중 2개
      • Using the 00 Phillips screwdriver remove the two screws in the corners.
      • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
      • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
      댓글 쓰기
    3. ExoPC Slate CPU Fan Replacement: 3 단계, 이미지 3개 중 1개 ExoPC Slate CPU Fan Replacement: 3 단계, 이미지 3개 중 2개 ExoPC Slate CPU Fan Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the tape covering the metal shield.
      • Remove the 12 screws using the Phillips #00 screwdriver.
      • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
      댓글 쓰기
    1. ExoPC Slate CPU Fan Replacement, CPU Fan: 4 단계, 이미지 2개 중 1개 ExoPC Slate CPU Fan Replacement, CPU Fan: 4 단계, 이미지 2개 중 2개
      • Remove the yellow tape securing the wires to the PCB board as well as the silver/grey tape.
      • Unscrew the six Phillips #00 screws.
      댓글 쓰기
    2. ExoPC Slate CPU Fan Replacement: 5 단계, 이미지 2개 중 1개 ExoPC Slate CPU Fan Replacement: 5 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Using tweezers, disconnect the connector in the top left.
      • Pull the fan heat sink away from the PC.
      • Remove the fan from the copper heat sink with the tweezers by releasing the metal clips.
      • Apply a sparing amount of thermal paste to each chip.
      • Attach the new or cleaned fan to the heat sink using the metal clips. Line up the heat sink with the screw holes and press down firmly to spread out the thermal paste.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Jonathon Cronin
회원 가입일: 10/29/18
337 평판
안내서 3개를 작성함
UMass Dartmouth, Team S2-G1, Peak Fall 2018 UMass Dartmouth, Team S2-G1, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G1
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 46
전체 시간: 644
