주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ExoPC Slate Camera Replacement
필요한 것
    1. ExoPC Slate Camera Replacement, Camera: 1 단계, 이미지 1개 중 1개
      • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
      댓글 쓰기
    2. ExoPC Slate Camera Replacement: 2 단계, 이미지 1개 중 1개
      • Using the 00 Phillips screwdriver remove the two screws in the corners.
      • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
      • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
      댓글 쓰기
    3. ExoPC Slate Camera Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the tape covering the metal shield.
      • Remove the 12 screws using the Phillips #00 screwdriver.
      • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
      댓글 쓰기
    4. ExoPC Slate Camera Replacement: 4 단계, 이미지 2개 중 1개 ExoPC Slate Camera Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use tweezers to disconnect camera cable from motherboard.
      • Remove the Phillips #000 screw that holds the camera in place.
      • Gently remove the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Aaron Moore
회원 가입일: 10/30/18
217 평판
안내서 2개를 작성함
UMass Dartmouth, Team S2-G1, Peak Fall 2018 UMass Dartmouth, Team S2-G1, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G1
3 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 45
전체 시간: 545
