주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Eyelash Extensions Replacement
필요한 것
    1. Eyelash Extensions Replacement, Eyelash Extensions: 1 단계, 이미지 1개 중 1개
      • Wash hands thoroughly and make sure that the station and tools are cleaned and disinfected.
      댓글 쓰기
    2. Eyelash Extensions Replacement: 2 단계, 이미지 1개 중 1개
      • Place the medical-grade tape under each eye, making sure that all the lower lashes are secured.
      댓글 쓰기
    3. Eyelash Extensions Replacement: 3 단계, 이미지 1개 중 1개
      • Make sure that the client feels comfortable with the tape on with their eyes closed.
      댓글 쓰기
    4. Eyelash Extensions Replacement: 4 단계, 이미지 1개 중 1개
      • Brush the eyelashes thoroughly using a mascara wand to remove the eyelashes that are ready to shed.
      댓글 쓰기
    5. Eyelash Extensions Replacement: 5 단계, 이미지 2개 중 1개 Eyelash Extensions Replacement: 5 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove all the grown-out lashes using the banana peel method.
      • Hold the natural lash in one clean tweezer and the eyelash extension in the other set of clean tweezers.
      • Gently pull the natural lash and the lash extension in opposite directions and peel the lashes apart like a banana.
      댓글 쓰기
    6. Eyelash Extensions Replacement: 6 단계, 이미지 1개 중 1개
      • Brush the eyelashes again using a mascara wand after removing all the grown-out lashes.
      댓글 쓰기
    7. Eyelash Extensions Replacement: 7 단계, 이미지 3개 중 1개 Eyelash Extensions Replacement: 7 단계, 이미지 3개 중 2개 Eyelash Extensions Replacement: 7 단계, 이미지 3개 중 3개
      • Put a drop or two of the eyelash primer on the micro swabs.
      • Dab the micro swabs on the eyelashes while making sure that it does not touch the eyelids as it can sting the client’s eyes.
      댓글 쓰기
    8. Eyelash Extensions Replacement: 8 단계, 이미지 1개 중 1개
      • Let it air dry or use a fan for a faster dry time.
      댓글 쓰기
    9. Eyelash Extensions Replacement: 9 단계, 이미지 1개 중 1개
      • Place a new lash extension using the eyelash extension adhesive of choice onto the natural eyelash, making sure that the eyelashes are isolated.
      댓글 쓰기
    10. Eyelash Extensions Replacement: 10 단계, 이미지 2개 중 1개 Eyelash Extensions Replacement: 10 단계, 이미지 2개 중 2개
      • Repeat Step 9 for both eyes until you are completely satisfied with your work.
      댓글 쓰기
    11. Eyelash Extensions Replacement: 11 단계, 이미지 1개 중 1개
      • Inspect, separate, and brush the lashes to make sure that there are no upper lashes stuck on the lower lashes.
      댓글 쓰기
    12. Eyelash Extensions Replacement: 12 단계, 이미지 1개 중 1개
      • Use a fan for 5-10 minutes to make sure that the adhesive is cured.
      댓글 쓰기
    13. Eyelash Extensions Replacement: 13 단계, 이미지 1개 중 1개
      • Gently remove the tape from under each eye.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
April Pantaleon
회원 가입일: 09/20/20
349 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 22
전체 시간: 820
