주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
F. PanelDue Firmware Update
  1. F. PanelDue Firmware Update, Downloads: 1 단계, 이미지 1개 중 1개
    • Download the latest stable firmware from the Duet Github and extract the zip file
    • Make sure you download the correct version. The PanelDue 5i and 7i both use the same firmware binary. The file you want is named "PanelDue-5.0i-7.0i.bin"
    • FYSETC documentation says to use the 5i/7i combined binary("PanelDue-5.0i-7.0i.bin") for their 5i and 7i screens. If you use the combined version for you FYSETC 5i/7i your color scheme will be incorrect.
    • You need to install "PanelDueFirmware-v3-7.0.zip" or "PanelDueFirmware-v3-5.0.zip"
    • Download and install Bossa
    댓글 쓰기
  2. F. PanelDue Firmware Update, Connecting to your PC: 2 단계, 이미지 1개 중 1개
    • Hold the erase button on the back of the PanelDue
    • Connect a USB Micro cable from your PC to your PanelDue. Release the erase button and press the reset button.
    • Identify the COM port the PanelDue is using.
    • Click Start->Control Panel->System->Device Manager. Expand Ports (COM and LPT)
    댓글 쓰기
  3. F. PanelDue Firmware Update, Flashing the Firmware: 3 단계, 이미지 1개 중 1개
    • Once connected open Bossa.
    • Select the port in the dropdown. Click Browse and select the PanelDue firmware
    • Select the checkboxes for Erase all, Lock, and Boot from flash
    • Click Write. Bossa will load the firmware to the PanelDue. Once upload is complete, click Verify.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
David Husolo
회원 가입일: 06/16/21
9,382 평판
안내서 33개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 25
전체 시간: 2,035
