주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fairphone 3 Rear Camera Module Replacement
필요한 것
  1. Fairphone 3 Rear Camera Module Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Fairphone 3 Rear Camera Module Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
    댓글 쓰기
  2. Fairphone 3 Rear Camera Module Replacement: 2 단계, 이미지 3개 중 1개 Fairphone 3 Rear Camera Module Replacement: 2 단계, 이미지 3개 중 2개 Fairphone 3 Rear Camera Module Replacement: 2 단계, 이미지 3개 중 3개
    • Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
    댓글 쓰기
  3. Fairphone 3 Rear Camera Module Replacement, Battery: 3 단계, 이미지 2개 중 1개 Fairphone 3 Rear Camera Module Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lever the battery up until you can get a good grip.
    댓글 쓰기
  4. Fairphone 3 Rear Camera Module Replacement: 4 단계, 이미지 2개 중 1개 Fairphone 3 Rear Camera Module Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the battery out of its recess and remove it.
    댓글 쓰기
  5. Fairphone 3 Rear Camera Module Replacement, Display Assembly: 5 단계, 이미지 1개 중 1개
    • Whenever a Phillips #00 screw is mentioned you can also unfasten it with a size #0 bit/screwdriver.
    • Remove the thirteen Phillips #00 screws (4 mm length).
    댓글 쓰기
  6. Fairphone 3 Rear Camera Module Replacement: 6 단계, 이미지 3개 중 1개 Fairphone 3 Rear Camera Module Replacement: 6 단계, 이미지 3개 중 2개 Fairphone 3 Rear Camera Module Replacement: 6 단계, 이미지 3개 중 3개
    • Make sure to insert the opening pick between the midframe and the display module and not into the small gap next to the screen. Otherwise you're going to pry up the screen instead of the whole display module.
    • Insert an opening pick between the midframe and the display module on the right edge of the phone.
    • Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
    댓글 쓰기
  7. Fairphone 3 Rear Camera Module Replacement: 7 단계, 이미지 2개 중 1개 Fairphone 3 Rear Camera Module Replacement: 7 단계, 이미지 2개 중 2개
    • Slide the opening pick around the bottom right corner and use it to disengage the plastic clamps at the bottom of the display module.
    댓글 쓰기
  8. Fairphone 3 Rear Camera Module Replacement: 8 단계, 이미지 2개 중 1개 Fairphone 3 Rear Camera Module Replacement: 8 단계, 이미지 2개 중 2개
    • Slide the opening pick along the left side to pry the display module up.
    • The display module should pop out of the midframe during this process. In case it doesn’t, check for remaining clamps you might have missed.
    댓글 쓰기
  9. Fairphone 3 Rear Camera Module Replacement: 9 단계, 이미지 2개 중 1개 Fairphone 3 Rear Camera Module Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the display assembly.
    • To reinstall the display-module press it into place on all sides until you can hear a snap from the plastic clamps to make sure it sits flush with the frame.
    • If you install a new display: The new display module comes with a white plastic cover held by 2 screws over the processor and the connectors. This needs to be taken off.
    댓글 쓰기
  10. Fairphone 3 Rear Camera Module Replacement, Rear Camera Module: 10 단계, 이미지 1개 중 1개
    • Remove the two 4.1mm-long Phillips #00 screws.
    댓글 쓰기
  11. Fairphone 3 Rear Camera Module Replacement: 11 단계, 이미지 2개 중 1개 Fairphone 3 Rear Camera Module Replacement: 11 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the camera connecting cable.
    댓글 쓰기
  12. Fairphone 3 Rear Camera Module Replacement: 12 단계, 이미지 2개 중 1개 Fairphone 3 Rear Camera Module Replacement: 12 단계, 이미지 2개 중 2개
    • Use a spudger to pry up the rear camera module.
    댓글 쓰기
  13. Fairphone 3 Rear Camera Module Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the rear camera module.
    댓글 쓰기
결론
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
취소: 해당 안내서를 완성하지 않았습니다.
다른 18명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Adriana Zwink
회원 가입일: 12/18/19
67,702 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 28,236개를 작성함
3가이드 댓글
How NOT to remove the display!
I just destroyed my display module a bit and had to fix it with glue. :(
This works better: https://www.youtube.com/watch?v=wGTYZNzg...
caroline - 답글 공유
I think this guide should mention that the camera connecting cable can become disconnected accidentally on its other end (under the metallic cover) which is easy to miss. This forum post helped me: https://forum.fairphone.com/t/be-careful...
The metallic cover can be removed easily after screwing off two Torx screws. Couple of people on the forum experienced this and it helped me solve my problem.
cmur2 - 답글 공유
Pas de problème pour changer le module. Les explications données par ifixit sont claires et aisées à suivre.
Eric Beaucarne - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 82
전체 시간: 9,824
