주요 콘텐츠로 건너뛰기
Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement
필요한 것
  1. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement, 2006 Honda CR-V Key Fob: 1 단계, 이미지 1개 중 1개
    • You will need to take the key off the ring.
  2. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • The second step is to take out the little screw on the back side of the key.
  3. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Unclip the back part of your key.
    • This part is super fragile.
  4. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • You will push the buttons from the front side to have the middle piece fall out.
  5. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 5 단계, 이미지 2개 중 1개 Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 5 단계, 이미지 2개 중 2개
    • Then you will unclip the middle part. There is one clip on each side of this piece. They are super fragile and can break easily.
  6. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 6 단계, 이미지 2개 중 1개 Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 6 단계, 이미지 2개 중 2개
    • Then push the buttons from the front side to push out a rubber insert.
  7. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • Then peel out the mother chip and replace your rubber insert.
    The 2005 key has plastic buttons. I wonder why they changed to soft buttons. That would be less durable.
    kctipton - 답글
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Spencer Greer
회원 가입일: 04/11/19
193 평판
안내서 1개를 작성함
댓글 2개
How do you remove the key from broken fob and put in new fob so you don’t have to incur the cost of cutting new key?
Me Me - 답글
Just open the fob, like in this tutorial. The key is just a piece of metal.
Then place the key in a new fob (or replace only the fob plastic case for a cheaper solution).
Brendan -
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 18
지난 30일: 68
전체 시간: 2,747
