주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fellowes T7CM Main Power Cord Replacement
필요한 것
    1. Fellowes T7CM  Main Power Cord Replacement, Fellowes T7CM Casing and Trigger Replacement: 1 단계, 이미지 1개 중 1개
      • Check to make sure the shredder is not plugged in to any electrical outlet.
      • Remove the shredder from the catch basket and place the silver side down on a flat surface.
      • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
      댓글 쓰기
    2. Fellowes T7CM  Main Power Cord Replacement: 2 단계, 이미지 1개 중 1개
      • Flip the shredder silver side down and place on a flat even surface.
      • Remove the manufacturer's label in order to gain access to the hidden screw hole.
      • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
      댓글 쓰기
    3. Fellowes T7CM  Main Power Cord Replacement: 3 단계, 이미지 1개 중 1개
      • Once all of the screws are removed, slowly pull apart the casing.
      • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
      • Use Caution during this procedure to prevent from damaging any of the internal parts.
      댓글 쓰기
    4. Fellowes T7CM  Main Power Cord Replacement: 4 단계, 이미지 1개 중 1개
      • Open the casing as shown to prevent tangling or damaging the wires.
      • Take note to how the trigger assembly is attached before removal.
      • The trigger assembly is one part and should come off all together with little to no force applied.
      • Remove the trigger assembly.
      댓글 쓰기
    1. Fellowes T7CM  Main Power Cord Replacement, Main Power Cord: 5 단계, 이미지 2개 중 1개 Fellowes T7CM  Main Power Cord Replacement, Main Power Cord: 5 단계, 이미지 2개 중 2개
      • Remove the wire holder. This is a small screwed in piece of plastic which holds the wires in place. The screw length is 10 mm and the head diameter is 6 mm.
      댓글 쓰기
    2. Fellowes T7CM  Main Power Cord Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the blade housing from the external case.
      • Remove the three screws from the blade housing. The screw length is 18 mm and the head diameter is 5 mm
      댓글 쓰기
    3. Fellowes T7CM  Main Power Cord Replacement: 7 단계, 이미지 1개 중 1개
      • Use Caution when lifting the blade housing from the casing.
      • Warning: Sharp Objects are now exposed.
      • Place the blade housing close to the case to ensure no damage occurs to the connected wires and that they remained attached to the casing.
      댓글 쓰기
    4. Fellowes T7CM  Main Power Cord Replacement: 8 단계, 이미지 1개 중 1개
      • Locate the main power cord.
      • Clip the wire and strip the remaining end of the wire. Twist the new cord together with the remaining old wire.
      • Use electrical tape in order to cover the wire splice.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
John Wisthoff
회원 가입일: 10/12/16
487 평판
안내서 3개를 작성함
IUPUI, Team 2-2, Baechle Fall 2016 IUPUI, Team 2-2, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S2G2
4 회원들
안내서 16개를 작성함
1가이드 댓글
Great instructions. Only question is what type of cord/plug to purchase? If found this on Amazon, but not sure if it’s correct.
GE 4306-31W5, Black, Household, DIY Repair, Replacement Plug Fix, Ideal for Lamps, TVs and Small Appliances, Indoor Rated, UL Listed, 54268,
https://www.amazon.com/Jasco-Products-54...
bishop5 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 39
전체 시간: 2,588
