주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fellowes T7CM On, Off, Reverse Switch Replacement
필요한 것
    1. Fellowes T7CM On,  Off, Reverse Switch Replacement, Fellowes T7CM Casing and Trigger Replacement: 1 단계, 이미지 1개 중 1개
      • Check to make sure the shredder is not plugged in to any electrical outlet.
      • Remove the shredder from the catch basket and place the silver side down on a flat surface.
      • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
      댓글 쓰기
    2. Fellowes T7CM On,  Off, Reverse Switch Replacement: 2 단계, 이미지 1개 중 1개
      • Flip the shredder silver side down and place on a flat even surface.
      • Remove the manufacturer's label in order to gain access to the hidden screw hole.
      • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
      댓글 쓰기
    3. Fellowes T7CM On,  Off, Reverse Switch Replacement: 3 단계, 이미지 1개 중 1개
      • Once all of the screws are removed, slowly pull apart the casing.
      • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
      • Use Caution during this procedure to prevent from damaging any of the internal parts.
      댓글 쓰기
    4. Fellowes T7CM On,  Off, Reverse Switch Replacement: 4 단계, 이미지 1개 중 1개
      • Open the casing as shown to prevent tangling or damaging the wires.
      • Take note to how the trigger assembly is attached before removal.
      • The trigger assembly is one part and should come off all together with little to no force applied.
      • Remove the trigger assembly.
      댓글 쓰기
    1. Fellowes T7CM On,  Off, Reverse Switch Replacement, On,  Off, Reverse Switch: 5 단계, 이미지 1개 중 1개
      • Unscrew both of the screws from the circuit board of the switch . Lift the circuit board away from the device. The screw length is 10 mm and the head diameter is 6 mm.
      댓글 쓰기
    2. Fellowes T7CM On,  Off, Reverse Switch Replacement: 6 단계, 이미지 2개 중 1개 Fellowes T7CM On,  Off, Reverse Switch Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the plastic switch case.
      • After the plastic case is removed, the switch can be replaced.
      • During the switch replacement, be careful of the springs that are held in side. They can potentially come loose and get lost.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Michael Aldrich
회원 가입일: 10/12/16
686 평판
안내서 5개를 작성함
IUPUI, Team 2-2, Baechle Fall 2016 IUPUI, Team 2-2, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S2G2
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 57
전체 시간: 4,495
