주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fellowes T7CM Shaft Replacement
필요한 것
    1. Fellowes T7CM Shaft Replacement, Fellowes T7CM Casing and Trigger Replacement: 1 단계, 이미지 1개 중 1개
      • Check to make sure the shredder is not plugged in to any electrical outlet.
      • Remove the shredder from the catch basket and place the silver side down on a flat surface.
      • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
      댓글 쓰기
    2. Fellowes T7CM Shaft Replacement: 2 단계, 이미지 1개 중 1개
      • Flip the shredder silver side down and place on a flat even surface.
      • Remove the manufacturer's label in order to gain access to the hidden screw hole.
      • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
      댓글 쓰기
    3. Fellowes T7CM Shaft Replacement: 3 단계, 이미지 1개 중 1개
      • Once all of the screws are removed, slowly pull apart the casing.
      • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
      • Use Caution during this procedure to prevent from damaging any of the internal parts.
      댓글 쓰기
    4. Fellowes T7CM Shaft Replacement: 4 단계, 이미지 1개 중 1개
      • Open the casing as shown to prevent tangling or damaging the wires.
      • Take note to how the trigger assembly is attached before removal.
      • The trigger assembly is one part and should come off all together with little to no force applied.
      • Remove the trigger assembly.
      댓글 쓰기
    1. Fellowes T7CM Shaft Replacement, Gear and Shaft: 5 단계, 이미지 2개 중 1개 Fellowes T7CM Shaft Replacement, Gear and Shaft: 5 단계, 이미지 2개 중 2개
      • Remove the three screws holding the internal case to the external case. The screw length is 18 mm and the head diameter is 5 mm.
      • Remove the internal case.
      댓글 쓰기
    2. Fellowes T7CM Shaft Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the feeding sensor by unscrewing the single screw holding it. The screw length is 10 mm and the head diameter is 6 mm.
      • This step may be unnecessary, but it will prevent the sensor from being damaged.
      댓글 쓰기
    3. Fellowes T7CM Shaft Replacement: 7 단계, 이미지 2개 중 1개 Fellowes T7CM Shaft Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the six screws on the gearbox.
      • Remove the gearbox cover to expose the gears.
      • The screw length is 34 mm and the head diameter is 7 mm.
      • The screw length is 26 mm and the head diameter is 7 mm.
      댓글 쓰기
    4. Fellowes T7CM Shaft Replacement: 8 단계, 이미지 3개 중 1개 Fellowes T7CM Shaft Replacement: 8 단계, 이미지 3개 중 2개 Fellowes T7CM Shaft Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the gears.
      • The larger gear located in the middle may require a screwdriver to pry off.
      • Remove the gear holder by unscrewing two screws that are holding it in place. The screw length is 14 mm and the head diameter is 5 mm.
      댓글 쓰기
    5. Fellowes T7CM Shaft Replacement: 9 단계, 이미지 2개 중 1개 Fellowes T7CM Shaft Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the pin in order to pull the casing off of the shafts.
      • Remove the casing in order to expose shafts.
      댓글 쓰기
    1. Fellowes T7CM Shaft Replacement, Shaft: 10 단계, 이미지 1개 중 1개
      • Remove the metal attachment that holds the two shafts together.
      댓글 쓰기
    2. Fellowes T7CM Shaft Replacement: 11 단계, 이미지 1개 중 1개
      • The shafts can now be pulled apart and any obstructions located between or on each of the shafts can be removed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Michael Aldrich
회원 가입일: 10/12/16
686 평판
안내서 5개를 작성함
IUPUI, Team 2-2, Baechle Fall 2016 IUPUI, Team 2-2, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S2G2
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 28
전체 시간: 1,730
