주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fender Starcaster Bridge Replacement
필요한 것
    1. Fender Starcaster Bridge Replacement, Loosen the Strings: 1 단계, 이미지 3개 중 1개 Fender Starcaster Bridge Replacement, Loosen the Strings: 1 단계, 이미지 3개 중 2개 Fender Starcaster Bridge Replacement, Loosen the Strings: 1 단계, 이미지 3개 중 3개
      • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
      • Repeat this for all six strings on the guitar.
      댓글 쓰기
    2. Fender Starcaster Bridge Replacement, Remove the Strings from the Tuning Pegs: 2 단계, 이미지 2개 중 1개 Fender Starcaster Bridge Replacement, Remove the Strings from the Tuning Pegs: 2 단계, 이미지 2개 중 2개
      • Be mindful of the string ends. They may be sharp and could puncture your skin.
      • It may be necessary to use pliers to remove string ends from the tuning peg.
      댓글 쓰기
    3. Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: 3 단계, 이미지 3개 중 1개 Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: 3 단계, 이미지 3개 중 2개 Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: 3 단계, 이미지 3개 중 3개
      • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
      • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
      댓글 쓰기
    1. Fender Starcaster Bridge Replacement, Bridge: 4 단계, 이미지 2개 중 1개 Fender Starcaster Bridge Replacement, Bridge: 4 단계, 이미지 2개 중 2개
      • On the back of the guitar, remove the plate covering the spring cavity. In the spring cavity, reduce the tension on the bridge springs by first loosening the retainer screws a bit.
      댓글 쓰기
    2. Fender Starcaster Bridge Replacement: 5 단계, 이미지 3개 중 1개 Fender Starcaster Bridge Replacement: 5 단계, 이미지 3개 중 2개 Fender Starcaster Bridge Replacement: 5 단계, 이미지 3개 중 3개
      • To remove the springs from the bridge, grip the end with pliers and pull up.
      • It is safe to use the body of the guitar for leverage.
      댓글 쓰기
    3. Fender Starcaster Bridge Replacement: 6 단계, 이미지 3개 중 1개 Fender Starcaster Bridge Replacement: 6 단계, 이미지 3개 중 2개 Fender Starcaster Bridge Replacement: 6 단계, 이미지 3개 중 3개
      • Be aware that the ground wire for the electronics of the guitar is routed through the body and soldered to the spring retainer.
      댓글 쓰기
    4. Fender Starcaster Bridge Replacement: 7 단계, 이미지 3개 중 1개 Fender Starcaster Bridge Replacement: 7 단계, 이미지 3개 중 2개 Fender Starcaster Bridge Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the screws from the front of the bridge.
      • It may be helpful to only loosen the outer screws as you remove the inner screws, in order to prevent damage to the guitar.
      댓글 쓰기
    5. Fender Starcaster Bridge Replacement: 8 단계, 이미지 1개 중 1개
      • With all six screws removed, lift up on the bridge to remove it from the body.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Christopher Hartigan
회원 가입일: 09/10/14
164 평판
안내서 5개를 작성함
Pasco Hernando, Team 5-3, Prince Fall 2014 Pasco Hernando, Team 5-3, Prince Fall 2014 회원
PHSC-PRINCE-F14S5G3
9 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 43
전체 시간: 3,126
