주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fender Starcaster Tuning Heads Replacement
필요한 것
    1. Fender Starcaster Tuning Heads Replacement, Loosen the Strings: 1 단계, 이미지 3개 중 1개 Fender Starcaster Tuning Heads Replacement, Loosen the Strings: 1 단계, 이미지 3개 중 2개 Fender Starcaster Tuning Heads Replacement, Loosen the Strings: 1 단계, 이미지 3개 중 3개
      • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
      • Repeat this for all six strings on the guitar.
      댓글 쓰기
    2. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: 2 단계, 이미지 2개 중 1개 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: 2 단계, 이미지 2개 중 2개
      • Be mindful of the string ends. They may be sharp and could puncture your skin.
      • It may be necessary to use pliers to remove string ends from the tuning peg.
      댓글 쓰기
    3. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: 3 단계, 이미지 3개 중 1개 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: 3 단계, 이미지 3개 중 2개 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: 3 단계, 이미지 3개 중 3개
      • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
      • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
      댓글 쓰기
    1. Fender Starcaster Tuning Heads Replacement, Tuning Heads: 4 단계, 이미지 2개 중 1개 Fender Starcaster Tuning Heads Replacement, Tuning Heads: 4 단계, 이미지 2개 중 2개
      • Using a wrench, remove the nuts around each tuning head post.
      댓글 쓰기
    2. Fender Starcaster Tuning Heads Replacement: 5 단계, 이미지 3개 중 1개 Fender Starcaster Tuning Heads Replacement: 5 단계, 이미지 3개 중 2개 Fender Starcaster Tuning Heads Replacement: 5 단계, 이미지 3개 중 3개
      • Next, remove the threaded retainer sleeve from each post.
      • Don't forget the washer.
      댓글 쓰기
    3. Fender Starcaster Tuning Heads Replacement: 6 단계, 이미지 2개 중 1개 Fender Starcaster Tuning Heads Replacement: 6 단계, 이미지 2개 중 2개
      • Next, remove the screws from the backside of each tuner.
      댓글 쓰기
    4. Fender Starcaster Tuning Heads Replacement: 7 단계, 이미지 2개 중 1개 Fender Starcaster Tuning Heads Replacement: 7 단계, 이미지 2개 중 2개
      • Finally, remove the tuning machine assembly from the headstock.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Christopher Hartigan
회원 가입일: 09/10/14
164 평판
안내서 5개를 작성함
Pasco Hernando, Team 5-3, Prince Fall 2014 Pasco Hernando, Team 5-3, Prince Fall 2014 회원
PHSC-PRINCE-F14S5G3
9 회원들
안내서 25개를 작성함
3가이드 댓글
Does the 2013 Starcaster take a 10mm tuning peg?
Brian Seese - 답글 공유
This is only the removal. Nothing After step 7. What about the actual replacement? What did you replace them with? Did it involve any machining?
Richard Caruso - 답글 공유
This is only the removal. What about the actual replacement? What did you replace them with? Did it involve any machining?
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 42
전체 시간: 3,434
