주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fishing Line Replacement
    1. Fishing Line Replacement, Fishing Line: 1 단계, 이미지 1개 중 1개
      • Thread fishing line through all eyelets on the fishing pole.
      댓글 쓰기
    2. Fishing Line Replacement: 2 단계, 이미지 1개 중 1개
      • At the top of the allotted seven to ten feet, thread the line through one hook of the bobber by depressing the opposite side of the bobber so that the hook is exposed.
      댓글 쓰기
    3. Fishing Line Replacement: 3 단계, 이미지 1개 중 1개
      • Repeat step two for the opposite end of the bobber, threading the line through the second hook.
      댓글 쓰기
    4. Fishing Line Replacement: 4 단계, 이미지 1개 중 1개
      • About one to two feet before the end of the line, thread a weight onto the line.
      댓글 쓰기
    5. Fishing Line Replacement: 5 단계, 이미지 1개 중 1개
      • Tie a knot around the weight's eyelet. (No specific knot needed, it just needs to stay in place.)
      댓글 쓰기
    6. Fishing Line Replacement: 6 단계, 이미지 1개 중 1개
      • At the very end of the line, thread the line through the eyelet of the lure about 6 inches.
      댓글 쓰기
    7. Fishing Line Replacement: 7 단계, 이미지 1개 중 1개
      • Twist the line around itself approximately five to six times.
      댓글 쓰기
    8. Fishing Line Replacement: 8 단계, 이미지 1개 중 1개
      • Thread the remaining line through the hole created by the previous step near the lure eyelet.
      댓글 쓰기
    9. Fishing Line Replacement: 9 단계, 이미지 1개 중 1개
      • Pull the knot tight.
      댓글 쓰기
결론
After step 9 you are ready to fish.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Trevone Martin
회원 가입일: 02/22/18
169 평판
안내서 1개를 작성함
1가이드 댓글
This is Joe from Durban Deep Sea Fishing Charters. This is a short and concise but very helpful guide to replace a fishing line. I will be sure to share this with my clients. Thanks guys
Joe Osborne - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 60
전체 시간: 2,477
