주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fitbit Surge Touchscreen Sensor Replacement
필요한 것
    1. Fitbit Surge Touchscreen Sensor Replacement, Touchscreen Sensor: 1 단계, 이미지 2개 중 1개 Fitbit Surge Touchscreen Sensor Replacement, Touchscreen Sensor: 1 단계, 이미지 2개 중 2개
      • Unscrew all four black 3 mm screws on the underside of the watch using a T5 screwdriver.
      댓글 쓰기
    2. Fitbit Surge Touchscreen Sensor Replacement: 2 단계, 이미지 3개 중 1개 Fitbit Surge Touchscreen Sensor Replacement: 2 단계, 이미지 3개 중 2개 Fitbit Surge Touchscreen Sensor Replacement: 2 단계, 이미지 3개 중 3개
      • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
      • Note: Part of the band is hard plastic.
      • Caution: Once the band is cut it cannot be reattached.
      댓글 쓰기
    3. Fitbit Surge Touchscreen Sensor Replacement: 3 단계, 이미지 2개 중 1개 Fitbit Surge Touchscreen Sensor Replacement: 3 단계, 이미지 2개 중 2개
      • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
      댓글 쓰기
    4. Fitbit Surge Touchscreen Sensor Replacement: 4 단계, 이미지 1개 중 1개
      • Use a PH000 screw head to undo the newly revealed silver 4 mm Phillips screws that were hidden beneath the glue.
      댓글 쓰기
    5. Fitbit Surge Touchscreen Sensor Replacement: 5 단계, 이미지 2개 중 1개 Fitbit Surge Touchscreen Sensor Replacement: 5 단계, 이미지 2개 중 2개
      • Using a metal spudger, push down on the plastic gray square clamps on the underside of the device to dislodge the whole silver backing.
      • Note: the buttons will also come off.
      댓글 쓰기
    6. Fitbit Surge Touchscreen Sensor Replacement: 6 단계, 이미지 1개 중 1개
      • Use a thin tool to pry the the device apart by lodging it between the clock face and back side of the device.
      • Note: A spudger may not be thin enough to fit in the seam of the device. We used the 6 inch metal ruler from the Pro Tech Toolkit.
      댓글 쓰기
    7. Fitbit Surge Touchscreen Sensor Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the touchscreen sensor using a spudger or your fingers.
      • Note: In this photo we removed the metal cover on the main PCB, but you do not need to remove it for this guide.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Keep in mind that the wristband will need to be cut for this repair and it cannot be reattached.
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Angela Pitts
회원 가입일: 10/11/16
1,190 평판
안내서 4개를 작성함
USF Tampa, Team 1-3, Leahy Fall 2016 USF Tampa, Team 1-3, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G3
3 회원들
안내서 4개를 작성함
5가이드 댓글
Is there a company that will perform this fix for me?
Terry Brown - 답글 공유
Where can I get a replacement sensor?
Francisco Cortez - 답글 공유
Isn’t any step missing in that instruction ?
Removing sensor will solve the issue ? How about adding new one ?
Erazm Gondoresku - 답글 공유
Hi, I didnt get the point, what should I do after removing sensor? Should I clean it or something? If I need to place a new one, maybe someone knows where to get one?
viktoras - 답글 공유
Is anyway I can buy the bus
Ajay Kumar - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 34
전체 시간: 3,313
