주요 콘텐츠로 건너뛰기
Fix False Paper Jam Error.
필요한 것
  1. Fix False Paper Jam Error., Determine if the Spring Needs Replacing: 1 단계, 이미지 2개 중 1개 Fix False Paper Jam Error., Determine if the Spring Needs Replacing: 1 단계, 이미지 2개 중 2개
    • The symptoms of this fault are:
    • The printer displays a 'Paper Jam' error, and tells you to remove the rear duplexer, and says that you may need to open the front cover too. When you touch 'OK', nothing happens, unless you open and close the front door.
    • When you open and close the front door and then touch 'OK', the printer mechanism moves a little and then it displays the error again. Occasionally the printer may move through most of a full initialization before stopping again.
    • If you bypass the door close mechanism (place an opaque object in the rectangular slot on the left hand side), you will see that the paper feed rollers are moving a small distance back, the carriage moves to the left slightly, then the feed rollers move forward and stop.
    • Shine a light into the printer, and check over on the far right for a small lever. This lever should slide to the right with gentle pressure, and spring back into position. If it doesn't slide back, try pulling it gently to the left.
    • If you can move the lever back and forth but it doesn't spring, then you need to disassemble your printer and replace this spring.
    Hi Mr.Robert Backhaus,
    Thanks a million..for saving my printer.
    I've contacted HP and they asked me to dispose of the printer as there is no service available for consumer printers.
    I've not go the skill to go all out following your useful and detailed step by step guide..
    What I did was I tried to move the lever you highlighted...it was jammed at first...then it snapped...I guess the spring broke...
    Then I use a rubber band to hook it to the metal panel...to simulate the return spring function..
    And it works.
    Not a proper repair...
    Just a Band It type of get it running solution.
    Thank you so much for your generous sharing.
    Else my OfficeJet Pro 8620 will never be able to function again because of a spring.
    Leehanvoon@yahoo.com
    Leehanvoon - 답글
    Robert, Thanks for the info!!
    I was able to move the lever which did not spring at all but the false paper jam error message is gone (yay!). I'm not sure how long it will last.
    I'm now confused as to how the "rubber band" solution is installed. What size rubber band? Where is the metal panel the rubber band is hooked to (as mentioned in Leehanvoon's reply)? Can you provide any insight?
    Thanks in advance for any advice. ~Audrey
    ale57intx@yahoo.com
    Audrey - 답글
    I haven't done the rubber band fix, but the idea would be to hook it around a few things on the back side of the right hand support plate, stretched across the back side of the lever to push it outwards.
    Robert Backhaus -
  2. Fix False Paper Jam Error., Prepare the Printer.: 2 단계, 이미지 2개 중 1개 Fix False Paper Jam Error., Prepare the Printer.: 2 단계, 이미지 2개 중 2개
    • Remove the printer from the optional second paper tray.
    • Pull out the paper tray from the front, and the duplexer from the rear.
    • Removing the print head (see the HP user guide) may also reduce the chance of ink leakage while working on the printer.
  3. Fix False Paper Jam Error., Control Panel: 3 단계, 이미지 2개 중 1개 Fix False Paper Jam Error., Control Panel: 3 단계, 이미지 2개 중 2개
    • Hold up the control panel with one hand, reach underneath it with the other, and pull firmly downward on the curved support to detach it from the display
    • Lifting the display further up, reach behind the brown plastic cover, and pull it forwards to release it
  4. Fix False Paper Jam Error., Control Panel: 4 단계, 이미지 3개 중 1개 Fix False Paper Jam Error., Control Panel: 4 단계, 이미지 3개 중 2개 Fix False Paper Jam Error., Control Panel: 4 단계, 이미지 3개 중 3개
    • Rest the machine on it's rear panel, so you can access the cable.
    • Lift up the brown clamp, and pull out the cable
    • Using a T-10 Torx screwdriver, undo the two screws beneath the display (pictured)
    • The display remains attached to the scanner assembly for now. If you need to detach it from the scanner - for instance, to operate the printer while it is open - you can detach it once the scanner assembly is removed.
  5. Fix False Paper Jam Error., Left Side (Controller Board) Panel: 5 단계, 이미지 3개 중 1개 Fix False Paper Jam Error., Left Side (Controller Board) Panel: 5 단계, 이미지 3개 중 2개 Fix False Paper Jam Error., Left Side (Controller Board) Panel: 5 단계, 이미지 3개 중 3개
    • On the back of the printer, remove the two screws on the right hand side (left-hand when viewed from the front.
    • Open the door on the front of the computer, and remove the one screw on the lower left-hand side.
    • Using a spudger lever firmly outwards on the lower rear side of the panel.
    • With your other hand, push the panel backwards, It will slide half a centimeter backwards and come free.
    • Could you help me? It would be useful if you could take an image of the rear of the printer, add it to this guide, so the locations of various screws can be marked.
  6. Fix False Paper Jam Error., Disconnect Cables: 6 단계, 이미지 1개 중 1개
    • Disconnect the scanner flatfex, sheet feeder and LED cables (marked in red).
    • Remove the earth strap (marked in yellow).
    • No other cables need to be removed at this time.
    Worth checking at this point that the paper outfeed drive belt is not slack or damaged - this can give the same error message. The belt is behind the circuit board.
    Chris Batchelor - 답글
  7. Fix False Paper Jam Error., Remove the scanner assembly: 7 단계, 이미지 2개 중 1개 Fix False Paper Jam Error., Remove the scanner assembly: 7 단계, 이미지 2개 중 2개
    • Remove the remaining screws around the top of the printer.
    • Lift the scanner assembly away from the printer.
    • If you need to detach the display, lay the scanner assembly upside down, lower the display assembly, push it to the right, and then adjust the angle of the display until it drops away from the scanner. Reconnect it to the flat-flex cable, and clip the support back into the rear to hold it. The printer will operate normally without the scanner.
  8. Fix False Paper Jam Error., Remove the output tray: 8 단계, 이미지 3개 중 1개 Fix False Paper Jam Error., Remove the output tray: 8 단계, 이미지 3개 중 2개 Fix False Paper Jam Error., Remove the output tray: 8 단계, 이미지 3개 중 3개
    • Depress the two clips at the rear of the output tray, and pull the tray forward.
    • Rest the printer on its rear panel, depress the two clips under the tray, and slide the white support clear of the tray.
    • Pull the output tray clear.
  9. Fix False Paper Jam Error., Remove the right hand side panel.: 9 단계, 이미지 1개 중 1개
    • Remove the single silver screw (pictured)
    • Remove the two screws from the rear left-hand side (right hand when viewed from the front)
  10. Fix False Paper Jam Error., Remove the Right-Hand Side Panel (cont.): 10 단계, 이미지 3개 중 1개 Fix False Paper Jam Error., Remove the Right-Hand Side Panel (cont.): 10 단계, 이미지 3개 중 2개 Fix False Paper Jam Error., Remove the Right-Hand Side Panel (cont.): 10 단계, 이미지 3개 중 3개
    • Release the one clip on the inside front of the panel.
    • Release the two clips on the underside of the printer.
  11. Fix False Paper Jam Error., Remove the Right-Hand Side Panel (cont): 11 단계, 이미지 2개 중 1개 Fix False Paper Jam Error., Remove the Right-Hand Side Panel (cont): 11 단계, 이미지 2개 중 2개
    • Pull outwards on the front to release a hidden clip.
    • Rotate the panel outwards until the clips on the rear of the panel detach.
    • If the panel doesn't detach easily, it may help to remove the screws securing the back panel first.
  12. Fix False Paper Jam Error., Remove the rear panel: 12 단계, 이미지 1개 중 1개
    • Remove the remaining screws on the rear of the printer.
    • Detach the rear panel.
  13. Fix False Paper Jam Error., Remove the power button cover: 13 단계, 이미지 3개 중 1개 Fix False Paper Jam Error., Remove the power button cover: 13 단계, 이미지 3개 중 2개 Fix False Paper Jam Error., Remove the power button cover: 13 단계, 이미지 3개 중 3개
    • Using multple tools and considerable force, unclip the power button cover from the bottom.
    • Concentrate on the points marked with arrows. This is the location of the clips. Forcing a plastic spudger in at these points should release this cover.
    • Release trims in the left-hadn quater panel
    • There are clips on the side, underneath, and two from the top.
  14. Fix False Paper Jam Error., Detach the front door.: 15 단계, 이미지 2개 중 1개 Fix False Paper Jam Error., Detach the front door.: 15 단계, 이미지 2개 중 2개
    • Detach the NFC connector from the circuitboard, (Socket location marked in red) and pull the cable free from its restraints.
    • Bend the flexible flap attached to the front door upwards, then pull the studs free from the guides.
    • Pull the three hinges out of their clamps, and remove the front door.
  15. Fix False Paper Jam Error., Remove the Front Panel: 16 단계, 이미지 3개 중 1개 Fix False Paper Jam Error., Remove the Front Panel: 16 단계, 이미지 3개 중 2개 Fix False Paper Jam Error., Remove the Front Panel: 16 단계, 이미지 3개 중 3개
    • Remove the power button, door sensor, and USB cables from the circuit board.
    • Slide back the catch on the Ctrl Panel socket, and remove the flat-flex.
    • Many repairs may not require this panel to be fully removed, so these cables may be left attached, if care is taken not to damage them.
    • Remove the 2 screws on the front left, and the one on the front right.
    • Release the clips in the paper output area
    • Pull the front panel free.
  16. Fix False Paper Jam Error., Release the carriage support.: 17 단계, 이미지 3개 중 1개 Fix False Paper Jam Error., Release the carriage support.: 17 단계, 이미지 3개 중 2개 Fix False Paper Jam Error., Release the carriage support.: 17 단계, 이미지 3개 중 3개
    • Remove the three screws from the bracket between the end of the carriage support and the case. Remove this bracket.
    • With clean hands or gloves, depress the sprung bracket on the right, and release the plastic sensor strip. Then undo it from the hook on the left side. Lay it over the print head, and secure it with a clean object.
    • It is essential that you do not crease, twist or soil this strip. Small amounts of ink can be removed with a mild solvent, such as isopropyl alcohol, but other solvents may remove the fine lines printed on it. It may be safer to remove it at this point, but it is hard to feed it back through the print head assembly.
    • Remove the two bolts holding the steel rod to the chassis, and slide it out of the printer.
    • Undo the two bolts holding the right side of the carriage support.
    • The rear bolt is in a deep hole, so if you are using a bit set and handle, you will need to get creative!
  17. Fix False Paper Jam Error., Remove the Cleaning Station.: 18 단계, 이미지 2개 중 1개 Fix False Paper Jam Error., Remove the Cleaning Station.: 18 단계, 이미지 2개 중 2개
    • Undo the single screw attaching the cleaning station to the carriage support.
    • If you have not already done so, put on your gloves now. The cleaning station is full of ink, and you can't handle it without getting ink on you.
    • Release the air lines from the clips in the cleaning station.
    • Detach the smaller hose from the T joint.
    • Pull up on the carriage support. This should give you enough room to work the cleaning station out of the printer.
    The plastic air hose comes out when you take the cleaning station apart, be sure to locate where it connects to, I’m not sure where the other end of the hose goes.
    Batman1 - 답글
  18. Fix False Paper Jam Error., Dissasemble Cleaning Station: 19 단계, 이미지 3개 중 1개 Fix False Paper Jam Error., Dissasemble Cleaning Station: 19 단계, 이미지 3개 중 2개 Fix False Paper Jam Error., Dissasemble Cleaning Station: 19 단계, 이미지 3개 중 3개
    • Release the clip on top of the station, and slide the front cover off
    • Undo the 4 screws on top, release the clip on the rear of the station, and lift off the top cover.
  19. Fix False Paper Jam Error., Continue Disassembly: 20 단계, 이미지 3개 중 1개 Fix False Paper Jam Error., Continue Disassembly: 20 단계, 이미지 3개 중 2개 Fix False Paper Jam Error., Continue Disassembly: 20 단계, 이미지 3개 중 3개
    • Lift out the wiper/cap assembly.
    • Release the clip on the left hand side, and remove the small moulding.
    • Carefully spring back the small black plastic blade retaining the lever, and lift it up out of the assembly.
    • This small plastic blade is thin and fragile. Push it back just enough to allow the support to push past it.
  20. Fix False Paper Jam Error., Dissemble Sprung Cog Assembly: 21 단계, 이미지 3개 중 1개 Fix False Paper Jam Error., Dissemble Sprung Cog Assembly: 21 단계, 이미지 3개 중 2개 Fix False Paper Jam Error., Dissemble Sprung Cog Assembly: 21 단계, 이미지 3개 중 3개
    • You should now be able to see, covered in lots of ink, the broken spring. My pictures were taken during reassembly, after I had given everything a thorough cleaning.
    • It is much nicer to work on this if you first give it a thorough cleaning. To do this you either need to remove the ink-soaked pads, (some of which are glued in), or wash the entire assembly with the pads in place, which means you will need to leave them a long time to dry.
    • My replacement spring, shown in these pictures, was wound from some fine music wire I had on hand, It is too flimsy, but seems to work OK. You should use a more substantial spring than this.
    • Open the clips on each side of the bar, allowing the spring retainer to move.
    • Slide the bar out the left hand side of the cleaning station, pulling the end cog and the spring retainer off the bar.
  21. Fix False Paper Jam Error., Reassemble the Sprung Cog Assembly.: 22 단계, 이미지 1개 중 1개
    • If you have not cleaned the entire station, at least wash the parts of the cog assembly, and mop up some of the ink in the station with paper towels or shop rags.
    • Poke the bar in through the left side, then place over it the replacement spring and the spring retainer. The clips of the retainer go towards the spring. Do not slide the retainer all the way home yet.
    • Place put the sliding cog over the bar, taking note of the direction. Slide the spring retainer home. The sliding cog will locate in the hole in the housing on the right.
  22. Fix False Paper Jam Error., Reassemble the cleaning station: 23 단계, 이미지 3개 중 1개 Fix False Paper Jam Error., Reassemble the cleaning station: 23 단계, 이미지 3개 중 2개 Fix False Paper Jam Error., Reassemble the cleaning station: 23 단계, 이미지 3개 중 3개
    • Replace the small molding on the left side.
    • Apply grease to the cog, bar, the rack under the wiper assembly, and any other places where the parts slide against each other.
    • Replace the lever. Ensure it hooks into the end of the white sprung cog assembly. Ensure that the lever moves smoothly back, pushing the cog on the other side out, and then springs firmly back into position.
    • Replace the top cover and secure it with the 4 screws.
    • Replace the front cover.
결론
Proceed to reassemble your printer, working back through the instructions in the reverse order. You can test your repair as soon as you have restored the carriage support, plastic encoder strip, and reconnected the cables connecting the front panel switches and control panel.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Robert Backhaus
회원 가입일: 11/10/12
1,030 평판
안내서 5개를 작성함
댓글 11개
Hi Robert,
Thank you very much for the nice guid mate :)
How could I realise and slide left the cartridge to be able to reach screws on “Step 17 Release the carriage support”?
Regards :)
Tarlan Isaev - 답글
HI ROBERT
Thanks a lot from Guadeloupe West indies
Jean Claude Guillaume - 답글
And it works.
Leehanvoon - 답글
Hi Robert, on my 8610 the little lever from Step 1 doesn’t move at all. There’s no play, whatsoever, in it. Is that an indication of the spring problem?
Matthew Hess - 답글
Hi, I facing same problem with paper jam error, everything was fine, after hours of troubleshooting I found that actual problem it was patten belt was defective. Anyway thank you very much.
jani j - 답글
I have this error too on an OfficeJet Pro 8600 Plus. I checked that black lever, and it seems to spring back okay. About half way to the right it’s okay, the second half it seems like it runs against something, but moves to the end. Then it comes back left okay. I tried sticking my hand inside and moving the lever left and right while clearing and pressing OK multiple times, so it seems like that lever doesn’t do anything for me. Maybe it’s a belt. But I sure appreciate you taking your time to create something like this to help others.
Thomas Tommy - 답글
That sounds, to me, that you have an actual jam - that there is something in the road that is preventing the head from moving back and forth.
That lever’s job is to make the paper feed mechanism work the cleaning station. When the print head is way over to the right, it pushes that lever, which pushes a cog out to mesh with the paper feed rollers. Then, with the head in that position, the paper feed mech makes levers and wipers in the cleaning station work. Then, when the head moves away, the spring pushes the lever back, pulling that cog away from the paper feed mech, allowing it to move freely. When the spring breaks, the cheaning station stays connected to the paper feed mech, jamming it.
If the lever moves right, and returns left by itself without sticking, then your problem is elsewhere.
Robert Backhaus -
Yes Robert, this has been the failure of a deposited HP Officejet Pro 8600, now it works again and has been salvaged of beeng waste! This has been the only hint of these kind of failures on internet.
wilhelm.von.grorgenwugs - 답글
I had been experiencing the same symptoms with an HP OfficeJet 8620 which I bought on Craigslist from a frustrated owner. Although I’m experienced in repairing laptops, the iFixit instructions would have required too much of an effort (and I already have an 8615 and 8710 which I use every day). I did, however, use a rubber band to act as a replacement spring (as suggested by another reader) and sure enough, the printer now works! Thanks so much for posting this information explaining the cause of the false paper jam error…it would have been such a waste to throw away what is otherwise a great printer for scanning to pdf or jpg, and even printing once in awhile!
Richert Au Hoy - 답글
What absolute precision....thank you for your effort and your time!
tinneycat - 답글
Thanks for your tutorial ! It saved search time and after found a similar spring in waste disposal site, the 12 years old printer works now !
Patrice Wauthier - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 82
지난 30일: 279
전체 시간: 26,782
