주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fixing Pop up Flash Receptacle
필요한 것
    1. Fixing Pop up Flash Receptacle, Battery: 1 단계, 이미지 1개 중 1개
      • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
      댓글 쓰기
    2. Fixing Pop up Flash Receptacle: 2 단계, 이미지 1개 중 1개
      • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
      댓글 쓰기
    3. Fixing Pop up Flash Receptacle: 3 단계, 이미지 1개 중 1개
      • Remove the battery from inside the battery housing and set the cover aside.
      댓글 쓰기
    1. Fixing Pop up Flash Receptacle, Fixing Pop up Flash Receptacle: 4 단계, 이미지 2개 중 1개 Fixing Pop up Flash Receptacle, Fixing Pop up Flash Receptacle: 4 단계, 이미지 2개 중 2개
      • The inside of the flash shoe has a removable cover which is just snapped in place.
      • Using the flathead screwdriver, pry up on the front end of the cover.
      • Warning: The cover is on tight and is tough to pry off.
      댓글 쓰기
    2. Fixing Pop up Flash Receptacle: 5 단계, 이미지 1개 중 1개
      • Loosen, but do not remove, the 4 screws on top of the flash shoe.
      댓글 쓰기
    3. Fixing Pop up Flash Receptacle: 6 단계, 이미지 1개 중 1개
      • Locate the black pludger sticking up out of the flash shoe.
      • The black pludger may not be visible, which is why the flash is broken. Just locate the hole to where it should be and move on to the next step.
      댓글 쓰기
    4. Fixing Pop up Flash Receptacle: 7 단계, 이미지 1개 중 1개
      • If you can remove the bracket from the camera to reset the hotshoe, this is preferable to using a paperclip to reset the sensors.
      • Push a paperclip in and out of the plunger hole, ensuring the plunger moves up and down freely.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Mark
회원 가입일: 04/20/11
197 평판
안내서 5개를 작성함
Cal Poly, Team 8-9, Regan Spring 2011 Cal Poly, Team 8-9, Regan Spring 2011 회원
CPSU-REGAN-S11S8G9
4 회원들
안내서 13개를 작성함
2가이드 댓글
What about the other way, where the external flash IS installed (and the camera is successfully communicating TTL focal length data to it) yet the camera still doesn’t believe there is an external flash installed? Sometimes twisting the external flash a little causes the camera to change its mind and then it works, but then it usually forgets by the next exposure.
Think this mechanism could be causing that behavior too?
Andrew - 답글 공유
Take the hotshoe off, and make sure they move freely. Once they're moving freely, reverse disassembly and make sure it works. This will ensure it is properly "reset".
Nick - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 58
전체 시간: 5,314
