주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Flashforge Nozzle Unclogging
필요한 것
동영상 개요
  1. Flashforge Nozzle Unclogging, Loosen the nozzle: 1 단계, 이미지 1개 중 1개
    • First, turn the printer off by flipping the switch located in the back of the printer to the OFF position.
    댓글 쓰기
  2. Flashforge Nozzle Unclogging, Unscrewing the extruder: 2 단계, 이미지 1개 중 1개
    • Get the smallest Allen Key that is included with the package, then unscrew it until the head of the screw is sitting above the assembly
    댓글 쓰기
  3. Flashforge Nozzle Unclogging, Taking out the nozzle: 3 단계, 이미지 2개 중 1개 Flashforge Nozzle Unclogging, Taking out the nozzle: 3 단계, 이미지 2개 중 2개
    • Press and hold the red latches that are on both sides, then you must gently pull the nozzle out while wiggling it a bit. The nozzle should come out.
    댓글 쓰기
  4. Flashforge Nozzle Unclogging, Taking out the clog: 4 단계, 이미지 1개 중 1개
    • With the nozzle out, cut or pull any filament sticking up from the top.
    댓글 쓰기
  5. Flashforge Nozzle Unclogging, Putting the nozzle back in: 5 단계, 이미지 1개 중 1개
    • After that, push the nozzle back in with the pins facing the back and the nozzle sign facing you. Push it in gently until it clicks.
    댓글 쓰기
  6. Flashforge Nozzle Unclogging, Tightening the screw: 6 단계, 이미지 1개 중 1개
    • With the same Allen Key, Screw the key in until it is flush with the assembly.
    댓글 쓰기
  7. Flashforge Nozzle Unclogging, Turning the printer back on: 7 단계, 이미지 1개 중 1개
    • With the switch located at the back, flip it to the On position. If the light shows up at the screen, Your printer is not done for and is in an OK position. If it does not post, you will have to take it to a repair shop.
    댓글 쓰기
결론
This should make your 3d printer work, I hope your printer was fixed, have a good day/night!!
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Wyatt
회원 가입일: 09/18/25
175 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 93
전체 시간: 471
