주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Flip MinoHD Display Screen Replacement
필요한 것
    1. Flip MinoHD Display Screen Replacement, Casing: 1 단계, 이미지 2개 중 1개 Flip MinoHD Display Screen Replacement, Casing: 1 단계, 이미지 2개 중 2개
      • With the plastic opening tool, remove labels from the Flip Mino HD. 2 small black screws should appear.
      • With the Phillips Screwdriver 000, unscrew the 2 screws and set aside in a safe place.
      댓글 쓰기
    2. Flip MinoHD Display Screen Replacement: 2 단계, 이미지 2개 중 1개 Flip MinoHD Display Screen Replacement: 2 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • With the plastic opening tool, gently pry the front casing away from the device by carefully running the tool around each edge and lifting.
      • Do not pull to remove the casing until all sides are loose. You may break or crack the case.
      • Once case is loose, flip up and over the device. Note that casing is still connected to the device.
      • Using tweezers, pull connecting strip to disconnect it from its socket on the logic board.
      댓글 쓰기
    1. Flip MinoHD Display Screen Replacement, Display Screen: 3 단계, 이미지 3개 중 1개 Flip MinoHD Display Screen Replacement, Display Screen: 3 단계, 이미지 3개 중 2개 Flip MinoHD Display Screen Replacement, Display Screen: 3 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Using tweezers, pull connecting strip away from its socket on the logic board.
      • With the plastic opening tool, take the display screen out of its socket by gently lifting each corner. Flip the screen up towards the logic board that it is still connected to.
      • With the spudger, gently lift the film underneath the display bracket and peel away. Set aside.
      • With the plastic opening tool, gently pry open metal display bracket to remove from logic board.
      • Using fingernail, pry black tape up from zif socket to remove the partially attached display screen.
      댓글 쓰기
    2. Flip MinoHD Display Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Now your display screen is liberated and ready to replace. To install a new one, follow these steps backwards.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Abigail Buckenberger
회원 가입일: 01/06/16
732 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 30
전체 시간: 1,581
