주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Flip Video LCD Screen
필요한 것
    1. Flip Video LCD Screen, Outer Shell: 1 단계, 이미지 2개 중 1개 Flip Video LCD Screen, Outer Shell: 1 단계, 이미지 2개 중 2개
      • Turn off the device and take the batteries out.
      • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
      댓글 쓰기
    2. Flip Video LCD Screen: 2 단계, 이미지 1개 중 1개
      • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
      댓글 쓰기
    3. Flip Video LCD Screen: 3 단계, 이미지 2개 중 1개 Flip Video LCD Screen: 3 단계, 이미지 2개 중 2개
      • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
      댓글 쓰기
    4. Flip Video LCD Screen: 4 단계, 이미지 1개 중 1개
      • Open battery door. This can be done by gently depressing and sliding the battery down downward.
      댓글 쓰기
    5. Flip Video LCD Screen: 5 단계, 이미지 1개 중 1개
      • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
      댓글 쓰기
    1. Flip Video LCD Screen, Circuit Board: 6 단계, 이미지 1개 중 1개
      • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
      댓글 쓰기
    2. Flip Video LCD Screen: 7 단계, 이미지 1개 중 1개
      • Slowly lift the left side of the circuit board.
      • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
      댓글 쓰기
    3. Flip Video LCD Screen: 8 단계, 이미지 1개 중 1개
      • Disconnect the USB port cable from the back side of the circuit board.
      댓글 쓰기
    4. Flip Video LCD Screen: 9 단계, 이미지 1개 중 1개
      • Slide out the battery contacts.
      • Battery contacts
      • Slot where battery contacts were located
      댓글 쓰기
    1. Flip Video LCD Screen, LCD Screen: 10 단계, 이미지 1개 중 1개
      • With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
      댓글 쓰기
    2. Flip Video LCD Screen: 11 단계, 이미지 1개 중 1개
      • Flip over the circuit board and unlock the two black tabs on the ribbon connector by sliding them upwards.
      댓글 쓰기
    3. Flip Video LCD Screen: 12 단계, 이미지 1개 중 1개
      • Gently pull out ribbon cable.
      • If the ribbon cable does not come out easily you may not have fully unlocked the ribbon cable connector in the previous step.
      • The LCD screen is now removed and can be replaced.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Elizabeth
회원 가입일: 04/15/10
100 평판
안내서 6개를 작성함
Cal Poly, Team 26-21, Regan Spring 2010 Cal Poly, Team 26-21, Regan Spring 2010 회원
CPSU-REGAN-S10S26G21
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 32
전체 시간: 5,748
