주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Flip Video Lens Replacement
필요한 것
  1. Flip Video Lens Replacement, Outer Shell: 1 단계, 이미지 2개 중 1개 Flip Video Lens Replacement, Outer Shell: 1 단계, 이미지 2개 중 2개
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
    댓글 쓰기
  2. Flip Video Lens Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
    댓글 쓰기
  3. Flip Video Lens Replacement: 3 단계, 이미지 2개 중 1개 Flip Video Lens Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
    댓글 쓰기
  4. Flip Video Lens Replacement: 4 단계, 이미지 1개 중 1개
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
    댓글 쓰기
  5. Flip Video Lens Replacement: 5 단계, 이미지 1개 중 1개
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
    댓글 쓰기
  6. Flip Video Lens Replacement, Circuit Board: 6 단계, 이미지 1개 중 1개
    • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
    댓글 쓰기
  7. Flip Video Lens Replacement: 7 단계, 이미지 1개 중 1개
    • Slowly lift the left side of the circuit board.
    • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
    댓글 쓰기
  8. Flip Video Lens Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the USB port cable from the back side of the circuit board.
    댓글 쓰기
  9. Flip Video Lens Replacement: 9 단계, 이미지 1개 중 1개
    • Slide out the battery contacts.
    • Battery contacts
    • Slot where battery contacts were located
    댓글 쓰기
  10. Flip Video Lens Replacement, LCD Screen: 10 단계, 이미지 1개 중 1개
    • With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
    댓글 쓰기
  11. Flip Video Lens Replacement: 11 단계, 이미지 1개 중 1개
    • Flip over the circuit board and unlock the two black tabs on the ribbon connector by sliding them upwards.
    댓글 쓰기
  12. Flip Video Lens Replacement: 12 단계, 이미지 1개 중 1개
    • Gently pull out ribbon cable.
    • If the ribbon cable does not come out easily you may not have fully unlocked the ribbon cable connector in the previous step.
    • The LCD screen is now removed and can be replaced.
    댓글 쓰기
  13. Flip Video Lens Replacement, Lens: 13 단계, 이미지 2개 중 1개 Flip Video Lens Replacement, Lens: 13 단계, 이미지 2개 중 2개
    • Flip over circuit board so the ribbon connector is facing up.
    • Remove the 2 stainless steel 3mm screws securing the lens to circuit board with the #00 Phillips screwdriver.
    • The lens can now be removed and replaced.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Elizabeth
회원 가입일: 04/15/10
100 평판
안내서 6개를 작성함
Cal Poly, Team 26-21, Regan Spring 2010 Cal Poly, Team 26-21, Regan Spring 2010 회원
CPSU-REGAN-S10S26G21
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 24
전체 시간: 4,978
