주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Flip Video Ultra USB connector Replacement
필요한 것
    1. Flip Video Ultra USB connector Replacement, USB connector: 1 단계, 이미지 1개 중 1개
      • Unlock the battery cover by sliding the switch to the unlock position.
      댓글 쓰기
    2. Flip Video Ultra USB connector Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the battery cover by sliding it down the camera.
      댓글 쓰기
    3. Flip Video Ultra USB connector Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the batteries.
      댓글 쓰기
    4. Flip Video Ultra USB connector Replacement: 4 단계, 이미지 1개 중 1개
      • Slide the black upper casing off from the device.
      • This is a bit hard to get off, so don't be afraid to use a bit of force. There is no lock.
      댓글 쓰기
    5. Flip Video Ultra USB connector Replacement: 5 단계, 이미지 2개 중 1개 Flip Video Ultra USB connector Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the six 1mm screws from front of the camera with the Phillips Head screwdriver.
      댓글 쓰기
    6. Flip Video Ultra USB connector Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the top casing from the bottom to reveal the inner circuit board.
      댓글 쓰기
    7. Flip Video Ultra USB connector Replacement: 7 단계, 이미지 2개 중 1개 Flip Video Ultra USB connector Replacement: 7 단계, 이미지 2개 중 2개
      • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
      • Remove the six 1mm screws with the 1 Phillips head screwdriver.
      댓글 쓰기
    8. Flip Video Ultra USB connector Replacement: 8 단계, 이미지 2개 중 1개 Flip Video Ultra USB connector Replacement: 8 단계, 이미지 2개 중 2개
      • Gently separate the circuit board from the casing.
      댓글 쓰기
    9. Flip Video Ultra USB connector Replacement: 9 단계, 이미지 2개 중 1개 Flip Video Ultra USB connector Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the three 1mm screws from the USB connector and back casing with the Phillips Head screwdriver.
      댓글 쓰기
    10. Flip Video Ultra USB connector Replacement: 10 단계, 이미지 2개 중 1개 Flip Video Ultra USB connector Replacement: 10 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Gently lift the usb connector using the Plastic opening tool.
      • Using tweezers, remove the cord from the motherboard by gently lifting the connector.
      • The connector will be easier to remove if you wiggle the tweezers while lifting.
      댓글 쓰기
    11. Flip Video Ultra USB connector Replacement: 11 단계, 이미지 1개 중 1개
      • Fully remove the USB connector and replace it with the new USB connector.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nathaniel Ruf
회원 가입일: 10/18/16
514 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-7, Martin Fall 2016 UMass Dartmouth, Team 5-7, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G7
3 회원들
안내서 10개를 작성함
2가이드 댓글
My USB port broke off so is there anyway I could save my videos that where om there
Corrina Guerrero - 답글 공유
Where do you purchase the replacement usb connector?
DeEtte Moore - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 26
전체 시간: 1,588
