주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Flipper Zero Button Replacement
필요한 것
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
    댓글 쓰기
  1. Flipper Zero Button Replacement, Remove the microSD card: 2 단계, 이미지 1개 중 1개
    • Eject the microSD card by pressing it with your fingernail.
    댓글 쓰기
  2. Flipper Zero Button Replacement, Remove the screws: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
    댓글 쓰기
  3. Flipper Zero Button Replacement, Open the back cover: 4 단계, 이미지 3개 중 1개 Flipper Zero Button Replacement, Open the back cover: 4 단계, 이미지 3개 중 2개 Flipper Zero Button Replacement, Open the back cover: 4 단계, 이미지 3개 중 3개
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
    댓글 쓰기
  4. Flipper Zero Button Replacement, Seperate the chassis from the top cover: 5 단계, 이미지 2개 중 1개 Flipper Zero Button Replacement, Seperate the chassis from the top cover: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    $5.49
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
    • Once the screws are removed, separate the chassis from the top cover.
    댓글 쓰기
  5. Flipper Zero Button Replacement, Disconnect the battery: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Spudger
    $3.99
    • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
    댓글 쓰기
  6. Flipper Zero Button Replacement, Disconnect the ribbon cable: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    iFixit Opening Picks (Set of 6)
    $4.95
    • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
    댓글 쓰기
  7. Flipper Zero Button Replacement, Release the battery chassis: 8 단계, 이미지 2개 중 1개 Flipper Zero Button Replacement, Release the battery chassis: 8 단계, 이미지 2개 중 2개
    • To release the battery chassis, lightly rock it back and forth while pulling the two parts apart.
    • Be sure to apply gentle and consistent pressure to avoid damaging the device.
    댓글 쓰기
  8. Flipper Zero Button Replacement, Remove the ribbon cable: 9 단계, 이미지 2개 중 1개 Flipper Zero Button Replacement, Remove the ribbon cable: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    $4.95
    • Use a plastic pick to lift the latch up to unlock the connector and carefully remove the ribbon cable.
    댓글 쓰기
  9. Flipper Zero Button Replacement, Unscrew the the button chassis: 10 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $5.49
    • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
    댓글 쓰기
  10. Flipper Zero Button Replacement, Seperate the button chassis: 11 단계, 이미지 3개 중 1개 Flipper Zero Button Replacement, Seperate the button chassis: 11 단계, 이미지 3개 중 2개 Flipper Zero Button Replacement, Seperate the button chassis: 11 단계, 이미지 3개 중 3개
    • To seperate the button chassis and the board, press the latch on the side shown below and pull the chassis away from the board.
    댓글 쓰기
  11. Flipper Zero Button Replacement, The button layout: 12 단계, 이미지 1개 중 1개
    • To remove the buttons you need to release the latches.
    • OK
    • D-pad
    • Back
    • The central button (OK) is removed after the navigation button (D-pad).
    댓글 쓰기
  12. Flipper Zero Button Replacement, Unlatching the buttons: 13 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Flathead 1.5 mm Screwdriver
    $1.99
    댓글 쓰기
  13. Flipper Zero Button Replacement, Remove the light diffuser: 14 단계, 이미지 3개 중 1개 Flipper Zero Button Replacement, Remove the light diffuser: 14 단계, 이미지 3개 중 2개 Flipper Zero Button Replacement, Remove the light diffuser: 14 단계, 이미지 3개 중 3개
    • Use a flat head screwdriver to release the light diffuser from the chassis and pull it out.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
33,346 평판
안내서 72개를 작성함
2가이드 댓글
I don't believe the top buttons on the plastic top layer are the problem. It's the physical button underneath the circuitboard.
Nutcheese99 - 답글 공유
ifixit screwdrivers are too big for step 3 you must use wera PH0 or similar size
Aeris (AZ) - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 26
지난 30일: 85
전체 시간: 4,232
