주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Floor Pump O-Rings Replacement
필요한 것
    1. Floor Pump O-Rings Replacement, O-Rings: 1 단계, 이미지 1개 중 1개
      • Detach the hose from its holder.
      댓글 쓰기
    2. Floor Pump O-Rings Replacement: 2 단계, 이미지 2개 중 1개 Floor Pump O-Rings Replacement: 2 단계, 이미지 2개 중 2개
      • Hold the base of the pump steady and twist the barrel counter-clockwise by hand until it completely unthreads.
      • If you are having troubles stabilizing the base and twisting the barrel, try standing on the base and using both hands to loosen the barrel.
      • Lift the barrel off the base.
      • When removing the barrel, be sure not to lose the bump stop O-ring. It may stick to the pump base, may be stuck inside the barrel, or may fall out when you remove the barrel.
      댓글 쓰기
    3. Floor Pump O-Rings Replacement: 3 단계, 이미지 1개 중 1개
      • Lift the pump handle until the top cap is expsoed
      댓글 쓰기
    4. Floor Pump O-Rings Replacement: 4 단계, 이미지 3개 중 1개 Floor Pump O-Rings Replacement: 4 단계, 이미지 3개 중 2개 Floor Pump O-Rings Replacement: 4 단계, 이미지 3개 중 3개
      • Place the ends of needle nose pliers into the top cap holes and turn counter-clockwise until the cap is loose.
      • Finish removing the top cap by hand.
      • Pull the pump plunger out of the barrel.
      댓글 쓰기
    5. Floor Pump O-Rings Replacement: 5 단계, 이미지 2개 중 1개 Floor Pump O-Rings Replacement: 5 단계, 이미지 2개 중 2개
      • Use a small flathead screwdriver to remove the plunger O-ring.
      • Use the screwdriver to remove the upper bump stop O-ring.
      • Install new O-rings.
      • Be careful not to over-stretch or cut the O-rings if you are using the screwdriver to install them.
      댓글 쓰기
    6. Floor Pump O-Rings Replacement: 6 단계, 이미지 2개 중 1개 Floor Pump O-Rings Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the lower bump stop O-ring from the pump base.
      • Remove and replace the base O-ring.
      댓글 쓰기
    7. Floor Pump O-Rings Replacement: 7 단계, 이미지 3개 중 1개 Floor Pump O-Rings Replacement: 7 단계, 이미지 3개 중 2개 Floor Pump O-Rings Replacement: 7 단계, 이미지 3개 중 3개
      • Insert the tips of needle nose pliers into the base cap holes and turn it counter-clockwise until it completely unthreads.
      • Remove the base cap from the pump base.
      • Remove and replace the base cap O-ring.
      • Re-assemble the pump using these instructions backwards.
      • Don't forget to set a new bump stop O-ring on top of the pump base before re-installing the pump barrel.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 633개를 작성함
1가이드 댓글
I was looking for ideas on how to “make" an O- ring. It can't be that difficult. I'll update when the plan comes together.?
RBizerka - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 71
전체 시간: 7,202
