주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fluke 77 Series III Dial Replacement
필요한 것
    1. Fluke 77 Series III Dial Replacement, Front Panel: 1 단계, 이미지 1개 중 1개
      • Be sure any test leads are out and the multimeter is off before opening the device.
      • Turn the multimeter so it is display side down.
      • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
      댓글 쓰기
    2. Fluke 77 Series III Dial Replacement: 2 단계, 이미지 1개 중 1개
      • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
      댓글 쓰기
    3. Fluke 77 Series III Dial Replacement: 3 단계, 이미지 2개 중 1개 Fluke 77 Series III Dial Replacement: 3 단계, 이미지 2개 중 2개
      • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
      • Pry the front panel from the back panel at the seam.
      • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
      댓글 쓰기
    1. Fluke 77 Series III Dial Replacement, Dial: 4 단계, 이미지 1개 중 1개
      • Hold front panel with both hands, with your thumbs on the dial axle. The dial axle is the metal rod that comes out from the middle of the white plastic rotating piece.
      • Firmly press down on the dial axle to separate the dial from the front panel.
      • If this is difficult to do with your hands, push the dial axle against something hard, like the edge of a table.
      댓글 쓰기
    2. Fluke 77 Series III Dial Replacement: 5 단계, 이미지 1개 중 1개
      • With the dial loosened, pull the white plastic rotating piece until it comes off the dial axle.
      댓글 쓰기
    3. Fluke 77 Series III Dial Replacement: 6 단계, 이미지 1개 중 1개
      • Finally, push again on the dial axle with your thumb while at the same time pulling the dial off the front panel with your other hand .
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kishan Patel
회원 가입일: 01/31/14
752 평판
안내서 3개를 작성함
Cal Poly, Team 2-10, Amido Winter 2014 Cal Poly, Team 2-10, Amido Winter 2014 회원
CPSU-AMIDO-W14S2G10
4 회원들
안내서 29개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 42
전체 시간: 3,475
