주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fluke 77 Series III Fuse Replacements
필요한 것
    1. Fluke 77 Series III Fuse Replacements, Front Panel: 1 단계, 이미지 1개 중 1개
      • Be sure any test leads are out and the multimeter is off before opening the device.
      • Turn the multimeter so it is display side down.
      • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
      댓글 쓰기
    2. Fluke 77 Series III Fuse Replacements: 2 단계, 이미지 1개 중 1개
      • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
      댓글 쓰기
    3. Fluke 77 Series III Fuse Replacements: 3 단계, 이미지 2개 중 1개 Fluke 77 Series III Fuse Replacements: 3 단계, 이미지 2개 중 2개
      • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
      • Pry the front panel from the back panel at the seam.
      • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
      댓글 쓰기
    1. Fluke 77 Series III Fuse Replacements, Battery: 4 단계, 이미지 2개 중 1개 Fluke 77 Series III Fuse Replacements, Battery: 4 단계, 이미지 2개 중 2개
      • When doing this next step, make sure to remove the battery slowly, so you don't damage the wires connecting the battery to the device.
      • Locate the 9V battery in the lower right corner of the device.
      • Pull the battery out of its terminal.
      댓글 쓰기
    2. Fluke 77 Series III Fuse Replacements: 5 단계, 이미지 2개 중 1개 Fluke 77 Series III Fuse Replacements: 5 단계, 이미지 2개 중 2개
      • Only pull on the metal snaps and battery. Pulling the cords may damage them.
      • Detach the two metal snaps from the battery.
      댓글 쓰기
    1. Fluke 77 Series III Fuse Replacements, Fuse: 6 단계, 이미지 2개 중 1개 Fluke 77 Series III Fuse Replacements, Fuse: 6 단계, 이미지 2개 중 2개
      • Replace a fuse only with a fuse identical in type, voltage rating, and current rating as specified by the back panel fuse rating label or the Fluke 77 Series III Service Manual. Inserting the wrong replacement fuse could create a fire hazard.
      • Locate the fuses near the bottom left corner inside the device.
      • Take note of which fuses belong in which location before removal. They are NOT interchangeable.
      • The .440 Amp fuse is located in the upper left hand fuse holder.
      • The 11 Amp fuse is located in the lower right hand fuse holder.
      • Lift the rounded edge of the fuse with one finger until that side is completely out of its holder.
      댓글 쓰기
    2. Fluke 77 Series III Fuse Replacements: 7 단계, 이미지 1개 중 1개
      • Grab the lifted edge of the fuse between your thumb and forefinger and pull it the rest of the way out of the device.
      • The fuse in the upper left corner can be tricky to remove. Use a plastic opening tool if needed.
      • Repeat steps 4 and 5 to remove the other fuse if you are replacing both fuses or if you are replacing a different part further on.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jessica Bombardier Shaw
회원 가입일: 01/29/14
1,018 평판
안내서 7개를 작성함
Cal Poly, Team 2-10, Amido Winter 2014 Cal Poly, Team 2-10, Amido Winter 2014 회원
CPSU-AMIDO-W14S2G10
4 회원들
안내서 29개를 작성함
2가이드 댓글
Its not that fuse but one like it on the main board in the stereo
Jennie Walters - 답글 공유
Don’t see a fuse on mine. No brand name. New battery. Continuity buzzer not working. And, Voltages Both AC/DC) show . When n ot connected to a voltage. ? Nothing looks out of place. Looks clean inside. Only thing i can think of is trying to get to the switch. That doesn’t look easy. Printed circuit board has to be pryed out. Looks like. WAIT,ther does look like a place for a fuse. But,,nothing there. How didi it work,,at all. Have had it for about 13 years.
rfloch4 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 76
전체 시간: 8,241
