주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Flydigi Apex 4 Trigger Assembly Replacement
필요한 것
  1. Flydigi Apex 4 Trigger Assembly Replacement, Trigger Assembly: 1 단계, 이미지 3개 중 1개 Flydigi Apex 4 Trigger Assembly Replacement, Trigger Assembly: 1 단계, 이미지 3개 중 2개 Flydigi Apex 4 Trigger Assembly Replacement, Trigger Assembly: 1 단계, 이미지 3개 중 3개
    • Ensure the controller is fully powered off before beginning.
    • Disconnect the USB-C cable if the controller is plugged in.
    • Remove any wireless adapter or dongle connected to your device.
    • Never work on the controller while it is powered on or charging. Doing so may damage internal components or cause injury.
    댓글 쓰기
  2. Flydigi Apex 4 Trigger Assembly Replacement: 2 단계, 이미지 3개 중 1개 Flydigi Apex 4 Trigger Assembly Replacement: 2 단계, 이미지 3개 중 2개 Flydigi Apex 4 Trigger Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the button caps and the magnetic faceplate of the controller.
    • It should come off with a tug.
    • Use a Phillips #00 screwdriver to remove the four screws securing the front of the controller to the frame.
    • Some screws may be hidden under grip pads or stickers. Gently peel these back if necessary.
    댓글 쓰기
  3. Flydigi Apex 4 Trigger Assembly Replacement: 3 단계, 이미지 2개 중 1개 Flydigi Apex 4 Trigger Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool into the seam between the front and back shell along the bottom edge of the controller.
    • Gently run the opening tool along the seam to release the plastic clips holding the two halves together.
    • Work your way around all edges until the back shell is fully unclipped.
    • Carefully lift the back shell away from the front half and set it aside.
    • Do not force the shell open. If you feel strong resistance, check for any screws you may have missed.
    댓글 쓰기
  4. Flydigi Apex 4 Trigger Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • With the controller open, identify the trigger assembly on the side you are replacing.
    • The trigger assembly consists of the trigger lever, the spring mechanism, and the analog sensor attached to the internal frame.
    • Take a photo of the internal layout before removing any components. This will help you reassemble the controller correctly.
    댓글 쓰기
  5. Flydigi Apex 4 Trigger Assembly Replacement: 5 단계, 이미지 3개 중 1개 Flydigi Apex 4 Trigger Assembly Replacement: 5 단계, 이미지 3개 중 2개 Flydigi Apex 4 Trigger Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Use a spudger or your fingernail to gently flip up the locking tab on the connector linking the trigger assembly to the main PCB.
    • Carefully pull the ribbon cable straight out of the connector.
    • Do not pull at an angle, as this may tear the cable.
    댓글 쓰기
  6. Flydigi Apex 4 Trigger Assembly Replacement: 6 단계, 이미지 2개 중 1개 Flydigi Apex 4 Trigger Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the screws securing each trigger assembly.
    • Lift the trigger assembly straight up and out of the controller frame.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
janavi
회원 가입일: 03/23/25
241 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-1, Shaddix Spring 2026 UMass Dartmouth, Team 3-1, Shaddix Spring 2026 회원
UMASSD-SHADDIX-S26S3G1
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 21
지난 30일: 86
전체 시간: 130
