주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fosera Scandle 200 Power Switch Replacement
필요한 것
    1. Fosera Scandle 200 Power Switch Replacement, Motherboard Removal: 1 단계, 이미지 1개 중 1개
      • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
      댓글 쓰기
    2. Fosera Scandle 200 Power Switch Replacement: 2 단계, 이미지 1개 중 1개
      • Gently separate the two halves of the casing.
      댓글 쓰기
    3. Fosera Scandle 200 Power Switch Replacement: 3 단계, 이미지 1개 중 1개
      • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
      • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
      댓글 쓰기
    4. Fosera Scandle 200 Power Switch Replacement: 4 단계, 이미지 1개 중 1개
      • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
      댓글 쓰기
    5. Fosera Scandle 200 Power Switch Replacement: 5 단계, 이미지 1개 중 1개
      • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
      댓글 쓰기
    1. Fosera Scandle 200 Power Switch Replacement, Power Switch: 6 단계, 이미지 1개 중 1개
      • Locate the Power Switch, and examine the area underneath the yellow plastic.
      • If you find something obstructing the movement, and you can remove it, you're done! If not, proceed with the replacement.
      댓글 쓰기
    2. Fosera Scandle 200 Power Switch Replacement: 7 단계, 이미지 1개 중 1개
      • Locate the three prong connectors for the switch on the back of the motherboard. The correct prongs will be right under the print which reads, "Scandle0410 REV.07"
      댓글 쓰기
    3. Fosera Scandle 200 Power Switch Replacement: 8 단계, 이미지 1개 중 1개
      • The soldering iron WILL be hot! Don't touch the iron's tip or any parts which have recently been in contact with the iron.
      • The solder around all three prong connectors will need to be melted individually. Push the prongs out with the soldering iron as the solder melts.
      댓글 쓰기
    4. Fosera Scandle 200 Power Switch Replacement: 9 단계, 이미지 1개 중 1개
      • Use the flat end of the spudger to pry the power switch from the motherboard. If the switch is still secured, use the pointed end of the spudger to poke the prongs out from the back.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jared
회원 가입일: 09/23/14
199 평판
안내서 1개를 작성함
USF Tampa, Team 12-5, Blackwell Fall 2014 USF Tampa, Team 12-5, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S12G5
4 회원들
안내서 23개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 33
전체 시간: 689
